Old 06-04-2002, 11:23 PM
gwako gwako is offline
vtec or not vtec
I have 92 civic si HB, I was wondering do these engines come with vtec, cause and if it does how would I know because I redlined this puppy, and I don't feel any differen ce where at 5200 rpm where people say vtec should kick in, and it doesn't vtec on the valve cover ???
Old 06-05-2002, 12:40 AM
jOYRiDe jOYRiDe is offline
no vtec on the valve cover = no vtec
Old 06-05-2002, 12:56 AM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
find the engine code on your car and we should tell if you car has vtec or not. the engine code is located on your engine block. it should be on the lower left side of the engine. here is an example..
make sure you wipe that area clean. after you find the code..report back to us.
Old 06-05-2002, 01:48 AM
hondaman-iac's Avatar
hondaman-iac hondaman-iac is offline
Send a message via AIM to hondaman-iac Send a message via Yahoo to hondaman-iac
nice f22a engine
hondaman-iac @ HondaStyle
92 ACCORD LX -- powered by a blown F22A1
Current Mods:
*rear lower tiebar
*AEM CAI
*Koni Yellow Struts
*Ground Control coilovers
*Energy suspension bushing kit
*front upper strut bar
*rear upper strut bar
PureHonda member since April 2001
Old 06-05-2002, 08:03 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
or, just look on the back of the head, on the distributor/passenger side.. there will be a little cylinder sticking out if there is, its the vtec solenoid
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 06-05-2002, 08:13 PM
YellowMaranello's Avatar
YellowMaranello YellowMaranello is offline
Send a message via AIM to YellowMaranello
You probably wont feel it even if it is VTEC. VTEC doesnt give the same sudden "kick" like a turbo, like most people make it seem.
Old 06-05-2002, 08:14 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
That is not true what is the matter with you. The Del Sol si's have D16z6 VTEC motors and they do not say it on the valve cover neither do the 96+ EX's they are VTEC also. If you have a 92 civic HB Si you have a D16z6 motor just like the EX's and yes it is VTEC and you will notice that your car will redline at 7200 rpms.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 06-05-2002, 08:37 PM
GSteg's Avatar
Originally posted by hondaman-iac
nice f22a engine
yup..it's my friend's F22A6 engine. :bandit:
Old 06-05-2002, 08:47 PM
93speed's Avatar
93speed 93speed is offline
Wish my headers looked that clean
Mine = nasty looking Time for some DC Sports
Old 06-05-2002, 09:24 PM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
He's from canada. Probably doesn't have vtec. It's an Si, not SiR
Old 06-06-2002, 12:14 AM
Well here's the answer the number on the engine is .....D16z6 , which makes it a VTEC..but the question is I don't really feel anything much is it becaue its a SOHC or because it might not be working..
Old 06-06-2002, 12:32 AM
you're not gonna feel that much, it's more a sound your might hear.
Old 06-06-2002, 12:38 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
92 and 93 dont say vtec on it, this is true for civic and del sols. If it has sparkplugs in front its a vtec, if they are in the back its not.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 06-06-2002, 06:29 PM
Dude the SiR is a DOHC VTEC. He's car is VTEC even in Canada.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 06-06-2002, 06:30 PM
You won't even hear it on the SOHC unless you have done some mods like Intake/ Headers/ Exhaust then you can hear it.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
