Old 03-14-2004, 12:59 AM
SilverStealth SilverStealth is offline
Turbo swap
Lets say i had a 94 SL with no engine in it, is it a bad idea to try to swap in a turbo engine? i know this has been asked before but i'm wondering exactly how hard it is to swap it in.
Plus i found a jdm engine with everything i need (i think).
ebay engine
http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
Sould i just say screw it and throw in a n/a?
Old 03-14-2004, 01:15 AM
Igovert500's Avatar
blue + red light magnet
Re: Turbo swap
Well, the twin turbo swap is a difficult swap, also realize that you may need to upgrade more then the engine...I have never done it, so do some more research, but I know its not just an engine swap. Also realize that the TTs have AWD, you have FWD, so a limited slip differential at the very least would be necessary to make sure you don't spin you're tires all the way through 4th gear. You may need some parts from a vr4..good luck tho
Old 03-14-2004, 09:40 AM
Teazrsnow Teazrsnow is offline
Send a message via AIM to Teazrsnow Send a message via Yahoo to Teazrsnow
Re: Turbo swap
You can do it if you get a front clip but otherwise it will be rough, and as far as the lsd you will need it but not right away , of course your tires will spin madly but if you can't handle it learn how to drive
Tyler Laabs
2nd Place Drag racing Fwd 3s National Gathering 03[
Old 03-14-2004, 11:21 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
This is one of those jobs that the difficulty will depend on your skill level and familiarity with the car. One of the guys down in Detroit area who did it took most of the summer. He knew the car well, but had not done any engine swapping up to that time. You'll appreciate the power difference if you have the time.
Resistance Is Futile (If < 1ohm)
EK HB...K20 Turbo swap, first K-swap, more to come... Mean_B16 WIP - Street 8 03-25-2007 03:58 PM
Easy Non-turbo to Turbo swap for 1g's. boyertownMidnight Engine, Transmission and Drivetrain 2 09-13-2006 09:09 PM
2.0 turbo vs 2.4 turbo swap the_game_rock 1st Gen 95-99 10 10-23-2005 01:11 PM
Turbo Swap? 95_GSX Engine, Transmission and Drivetrain 11 05-05-2003 10:39 PM
turbo swap Zracer 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 1 06-30-2002 02:21 PM
