Go Back   Automotive Forums Car Chat > Cars in General
Old 03-13-2004, 11:22 PM
panzershreck panzershreck is offline
engine cleaning
whats the best way to get dirt, grime, and oil off an engine block?
Old 03-14-2004, 09:42 AM
BullShifter's Avatar
Re: engine cleaning
Best way is to have it steam cleaned by a pro.
Old 03-16-2004, 08:23 PM
mcpbw mcpbw is offline
Send a message via AIM to mcpbw Send a message via Yahoo to mcpbw
Re: engine cleaning
do not be intimidated by engine cleaning. spray a gentle degreaser (simple green diluted 50/50) on a warm (not hot engine) and allow to dwell for 5 min or so. lightly mist engine occasionally to keep from drying. (unless it is an older vehicle you will not need to cover any electronics (cover open intakes though) just do not spray them directly with high pressure.) agitate with a scrub brush and then rinse. run engine for 5 minutes to dry then apply a WATER BASED dressing to all rubber and plastic with a soft towel (cotton or microfiber). you can also use a steam cleaner but I would not go buy one if just for this.
Eric
Old 04-09-2004, 11:30 AM
Three_Fingers Three_Fingers is offline
Re: engine cleaning
Believe it or not, Tide laundry detergent is one hell of a degreaser.
Old 04-20-2004, 09:55 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
If your just doing the block, boiling is the way to go. Open up all your freeze plugs and oil galleries. Those chemicals and scolding water will clean out EVERYTHING, and you'll be ready for a fresh coat of high-temp paint! (after you spray it off) Cost will vary on the shop you go to. Works great but its not free.
engine clean pull C/K 7 08-14-2004 02:26 AM
Blown intake gasket/Engine clean up Captbeancounter Lumina 4 04-29-2004 02:15 PM
Engine Cleaning?? Nation Cars in General 5 04-27-2004 01:25 AM
Engine Cleaning frogg Engine 8 01-20-2002 04:33 PM
Engine Cleaning Products frogg Engine 1 10-31-2001 11:48 PM
