Mine is 95' Aurora. I have to turn your head down to the right and see from the transmission when driving at night. Any light or signal on the dash to indicate those status?
Usually not a problem on other cars. |
Mine is a 98 and I know what you mean. It is rather difficult at night to see the selector position. I have never noticed any dash indicator, though it is a really great idea.
Re: Any indicator on the dash that indicates "Park" "Reverse""Drive"
Does the area under the PRNDL markings light up blue?
Does the "indicator" arrow (to point out which gear you're in) light up orange? If you're missing one or both of these, you either have bulb(s) burned out, or the wires are broken (common problem, usualy due to careless disassembly of the center console)... --Robert |
Just R&R'd my center console, my gear selector indicator wasn't working. Thought it was the bulb. It was the wiring, broken. Along with the wiring for the power shift button. Looks really nice to have the selector working.
Re: Re: Any indicator on the dash that indicates
I had my gear indicator light on the console fail. Turns out it was the bulb. Easy fix, you need to open the arm rest cover, and you will see screw heads. Take them out and its nice and easy to lift everything out. It would be nice to see something on the dash tho, like on the 2000+ Bonnevilles with the P NOD321 shown vertically.
Interestingly enough. When the dealer removed the gear shifter, the service guy noticed wires dangling from the Power Trans button. Apparently its a wire length problem from the factory. Meaning, simply not enough wire and when you put the car into 3 or OD the wires would pull and evantually seperate. He added 1.5" of spliced extra wire and problem solved.
1997 Aurora "Aurora Snow" 250++HP 4.0L Modified Aurora V8 w/Autobahn Performance On Deck: RSM intake, RSM 80mm TB ![]() Administrator, www.oldsmobileforums.com Administrator,Aurora Club of North America Administrator, www.bonnevilleclub.com Adminstrator, www.ontariobonnevilleclub.com Coming Soon |
My 2001 Has the gears showing vertical right in the center of the dash behind the steering wheel between tach and speedo with a light that shows what gear it is in. This only shows when car is running. I don't know about the older models.
