Old 03-12-2004, 10:21 PM
rsclipse27 rsclipse27 is offline
Need Help With Check Engine!
Hey I wanted to see if you guys could help me out..I have a 98 Eclipse RS and the check engine light is on..but I heard there was a way without bringing it to the shop to turn it off...Like there was a fuse you could pull out and plug back in and it'll be gone...Does anyone know which one it is? Or if there is another way to get the check engine light turned off other then going to the shop? Thanks a lot for your help!
Old 03-12-2004, 11:30 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Need Help With Check Engine!
Pull the negative cable off the battery for about 5 minutes. Then put it back on. But if the problem is still there it will come back on.
For Sale 98 Eclipse GS, 5 spd
Old 03-14-2004, 12:02 AM
joemathews's Avatar
joemathews joemathews is offline
If the O2 sensor is the problem, will unhooking the battery solve the check engine light on a talon tsi awd?
1996 Eagle Talon
Old 03-14-2004, 12:18 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
If your o2 sensor is shot, resetting the ECU won't fix it again.. it will just take a new survey of your systems, and find the o2 sensor bad again.
Old 03-14-2004, 10:04 AM
joemathews's Avatar
Ah okay, that figures. But I guess there isn't anything damaging about a bad o2 sensor, besides having a nagging Check Engine light on in the instrument cluster. Or if you drive without the o2 sensor working, can it be damaging to your engine?
1996 Eagle Talon
Old 03-14-2004, 05:22 PM
JoeWagon's Avatar
Banned
Depends which o2 sensor it is. The first one (closest to the engine, in o2 sensor housing) regulates fuel for a warmed up car... so that makes it pretty important. I think if it goes bad, your car will revert to a pre-set fuel table by MAS signal, and you'll get bad gas milage. It's not good to run the car off stoich in the long run.
If it's the cat o2 sensor, it won't affect anything.
need help with check engine codes yechiel Impala | Impala SS 1 02-19-2008 09:20 PM
help with check engine light fault code tcc excoupe23 3 Series 0 08-07-2007 04:35 PM
Need help with check engine light code 401 jumpytoad Taurus | Taurus Wagon 2 10-31-2005 12:30 PM
nedd help with check engine light! silent_dan Focus | C Max 10 08-04-2005 05:59 PM
need help, flashing check engine light edd863 Camaro Discussions 6 11-17-2004 02:48 PM
