Old 11-03-2004, 12:38 PM
edd863 edd863 is offline
need help, flashing check engine light
I just started my 97 trans am today and it started up a little wierd, and then the check engine light started flashing for a bit then stayed steady. I read that it means a misfire occured, but it starts up fine now, should i just ignore the light or should i get it fixed?
Old 11-03-2004, 12:56 PM
oh yeh, after the misfire happened this wierd smell started coming out of the car.
Old 11-03-2004, 01:50 PM
Kurtdg19's Avatar
Kurtdg19 Kurtdg19 is offline
Send a message via AIM to Kurtdg19
I would first check your spark plugs (and wires) and make sure they are not worn. Also be sure that they are gapped properly.
Old 11-03-2004, 04:26 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: need help, flashing check engine light
I would get your PCm scanned to see if its setting any codes besides just missfiring and its always a good idea to get any issue like this fixed as soon as possible in 99% of the time it just gets worse.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-03-2004, 08:30 PM
JackDaniels386 JackDaniels386 is offline
was that weird smell like rotten eggs? the flashing check engine light sometimes means that one of your cylinders is being flooded with fuel, and the excess fuel screws up your cat. when a cat. starts to go bad, it starts smelling like rotten eggs.
Old 11-03-2004, 10:42 PM
yeah, it was rotten eggs. just brought it to my local mechanic. he said it just needs a regular tune up, so im bringing it in next week for new plugs, wires, etc.
Old 11-17-2004, 02:48 PM
1991L98G92 1991L98G92 is offline
On 1996 and newer vehicles (OBD2) a flashing check engine light (service engine soon) mean that the computer sees a "catalyst damaging" problem. When the light stops flashing, the catalyst damaging problem has stopped. The light is on because there is an emission related code stored. After 2 consecutive drive cycles if the computer hasn't seen the problem again it will turn the light out. That would be an intermittent code. In my experience, the light stays on meaning there is a computer system problem that needs to be addressed.
Cal Smog Tech
