Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-12-2004, 06:39 PM
87delta88 87delta88 is offline
Unhappy 1987 Delta 88 idle problem
I have a 1987 Olds Delta 88 RB with the 3.8L odd fire V6 and 4 spd auto w/OD, 142000 miles.
At idle the engine runs very rough. With the lights and AC on, the car will sometimes die when slowing down from 55+. It has also died while idling, with both lights and AC on.
The voltmeter will range from 12-14 VDC at idle, but stay close to 14 when driving. The AC works fine.
There are no codes that come up on the diagnostic test.
The spark plugs are two months old, though the plug wires are a couple years old (I think).
Thanks!
Old 03-12-2004, 09:09 PM
W-44Olds W-44Olds is offline
Re: 1987 Delta 88 idle problem
Hmm... How is it when you first start the car ? Is it fine or do the same thing ? Or does it only do it once the car has ran awhile ?
Old 03-13-2004, 12:18 AM
It does it whether it is hot or cold, though it is worse when cold.
Old 06-14-2004, 05:51 PM
SQUAREMAN81 SQUAREMAN81 is offline
Try changing the throttle positioning sensor located on the main throttle boddy. I recently had this problem.
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
1987 Grand Marquis 5.0L FAST IDLE problem Johnobub Grand Marquis 3 10-09-2009 08:10 AM
Idling Problem williamjbronski Cavalier Problem Diagnosis 2 08-10-2009 10:39 AM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
