View Poll Results: What mustang should I get? (read below first!)
94-96 mustang V6, 96 cobra 4.6 swap 0 0%
94-96 mustang GT, 96 cobra 4.6 swap 1 33.33%
other idea (tell me about it below!) 2 66.67%
none, it will never work 0 0%
Voters: 3. You may not vote on this poll
Old 03-11-2004, 10:30 PM
jaronervin jaronervin is offline
Send a message via AIM to jaronervin
Question which should I choose?
OK, this might sound a little confusing, so just bear with me. I want to buy a 1994-1996 Mustang, preferably with high miles or slight work needed, to keep the price down. Then, I'd like to pull the engine, and drop a 1996-1998 Cobra engine into it. I've heard that it is VERY expensive to convert a V6 to V8, so would I be better off getting a GT, and swapping the engine? Does my idea sound like it could work? If so, where can I find a good engine? Thanks!! Jay
Old 03-11-2004, 11:14 PM
poison_ivey poison_ivey is offline
Send a message via AIM to poison_ivey
Re: which should I choose?
why not get the 94/95 5.0 and build that engine up? your gonna get the cobra engine and rebuild it, right? if i were in you position, i would rebuild the 5.0, maybe even stroke it to a 331 and blow it.i guessing it will cost about the same, and be just as/more powerful. just my opinion.
but if you do go cobra, then you probably should get 96/97 (4.6 motor). i guessing the wiring harnest is the same (im not even 70% sure) but you do have to get a new harness for sure if you get the 94/95 (has 302). good luck on what ever you do.
"Nothing is better than eternal happiness. Ham sandwiches are better than nothing. Therefore, ham sandwiches are better than eternal happiness."
Old 03-11-2004, 11:16 PM
o and also: if you do get a 94/95 then you better off w/ the v6... cheaper
Old 03-11-2004, 11:24 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
There is no completely cheap way to do this but here is the cheapest way. Get a 96-up GT with a blown(as in no good) motor. Now buy a 96-01 Cobra motor/tranny with complete wiring harness and computer($6,000). And start swapping! some small things here and there left to get but not bad.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 03-12-2004, 12:18 AM
eillob's Avatar
eillob eillob is offline
94/95 mustang GT and get a blown 331. Thats my vote. I would stay away from the V6 as cheap as you can get the 94 or 95 GT with high miles they are already set up and ready for the new V8.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Accord or Civic, just starting out which to choose? srdjs1 General Discussion 11 09-21-2003 04:44 PM
which to choose.. jedi Street Bikes 7 08-08-2003 10:03 AM
Which to choose? Kassel 3 Series 6 05-22-2003 01:53 AM
Which to choose? i_rebel COMPLETELY off-topic 5 01-30-2003 12:53 AM
Which to choose for my 2001 civic coupe?? 2001_Civic_Coupe Tires and Wheels 2 05-05-2002 02:24 PM
