Old 03-11-2004, 07:13 PM
travsstuff travsstuff is offline
Send a message via Yahoo to travsstuff
HELP homemade turbo or something
Okay I have a question. I was wondering, if I re-route my air intake hose to the grill and then use the whole grill as an intake, and somewhere there put a fan. Would that be about like a turbo? I don't know. I'm 15 and really bored. Would that work? Or do I need to do something else. HELP!
Old 03-11-2004, 07:33 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: HELP homemade turbo or something
You are talking about a ram air effect, which is an old performance trick. It works, but is no substitute for a turbo, as you must be doing very high speeds to duplicate the 7-10 psi of boost you get with a turbo. Also, it does not work well for carburetors unless the ehtire carb is pressurized. Its better for EFI.
Old 03-11-2004, 07:42 PM
is there a way that I could reproduce that 7-10 psi effect that you talked about
Old 03-12-2004, 09:34 AM
SaabJohan SaabJohan is offline
Yep, if you go around 1100 km/h and the intake of your car can reduce the air speed closer to zero then you can get 7 psi or so.
Help Help. I screwed something up chrissbee77 Grand Prix 21 04-05-2009 12:42 AM
homemade turbo rigit Camaro Discussions 120 03-26-2006 06:16 PM
Homemade Turbo!? BackseatJesus Eclipse 2000+ 20 09-29-2004 10:49 PM
homemade turbo or mini me?? 93weed_eater '88 - '91 Civic | CRX | Wagon | Shuttlee 11 07-11-2003 11:19 PM
homemade turbo setup help Tominos Forced Induction 4 07-25-2002 01:56 PM
