Old 07-10-2003, 11:28 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
homemade turbo or mini me??
my friend is about to trade me his crx (along with a port an polished y8 head uninstalled) for my teggy. I can't decide if i should just do the head swap or sell the head to start my turbo project. IF i do the mini me i want to use the V-AFC to control the vtec and tune it right. But i want a turbo so bad it isn't funny. I was thinking I could do the mini me and turbo it later but with the high compression from the head swap its kinda iffy. So i was wondering anyone thoughts on this.
I also have a questions about useing the V-AFC. I know you can activate the VTEC with an rmp switch but i want the capability to tune the fuel. On the other hand i only have a vague idea how this will work. I think you hook up the V-AFC to the ecu and it intercepts signals for the fuel curve and adjusts them to your settings right?? ok so does that mean ill have to go grab the ecu out of a ex and wire it all up to use the V-AFC. Any body whos has done this please give me some knowledge.
Old 07-10-2003, 11:35 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
What about getting a mini-me, building it up, then turbocharging? Once you feel that boost, you'll be addicted, that's for sure.
As for the V-AFC/VTEC issue, I am not quite sure..I don't have any experience with this problem..I'm sure someone here has, however.
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
Old 07-11-2003, 12:42 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
i have the fields vtec controller and i can control my fuel setting thru incriments thruout the rpm range and i have the pm6 ecu*stock*, is the crx an si? if it is i would say sell the y8 head and just go for turbo on that motor, youll probably be much happier that way
2002 Acura TL Type S
1991 Honda Crx Si
Old 07-11-2003, 04:10 PM
yea its an si. but i think ill go with the mini me build then do the turbo that way i can run more boost. so you use the fields controller to activate the vtec right? did you have to wire the vtec to the ecu for that to work or just run a wire to the controller.
Old 07-11-2003, 04:25 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
personally i'm not into the mini-me. more trouble than it's worth consdiering how cheap sohc vtec's have become. but, that is just my opinion...different strokes for different folks.
as for turbo, dropshop has some info i think you will find usefull. please stop by: http://www.thedropshop.tv/vafc.htm. dropshop is a fellow civic & crx owner who owns/runs a performance shop. i've known him quite awhile now and i would say it's safe to say he's addicted to turbo
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-11-2003, 05:29 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
I would sell the head and go turbo. The turbo will be easier to manage/safer with the lower compression of the a6. That's just my opinion though. The dropshop vafc hack is sweet, I'm gonna use it for my turbo project. I ordered a vafc last week, and I'm workin' on gettin' the injectors right now.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 07-11-2003, 05:49 PM
what makes you think you can run more boost? because you have a vtec head? nope, sell the head go turbo
1991 Honda Crx Si
Old 07-11-2003, 06:14 PM
kapt kapt is offline
Send a message via AIM to kapt
all motor is the way to go. if u want to pull strong consistent 1/4's and at the same time have a well rounded daily driver then u should beef up the motor.
how much are u gonna spend on a turbo, parts, etc? just swap in a gsr b17 or b18. a kid i know has a rex with a b18 and he owns my fkn car. i would def go with ur motor before u start throwing around boost.
Buildin up the b16 before i drop it in the CRX!!!
New 1989 CRX - i/h/e ;o
(retired)1990 Honda Civic DX HB - JDM b16a w/ hasport motor mounts, DC Sports Intake, APC short throw shifter, banzai motorsports muffler, neuspeed 2.5 inch drop pro springs, tokico blue shock/ struts, polyurethane energy suspension, dc sports rear strut tower brace, toucan front strut tower brace, JDM CRX rotors/calipers, Venom high-flow fuel pump, AEM fuel pressure regulator.
http://www.geocities.com/kaptr1d
Old 07-11-2003, 06:25 PM
no i don't mean i can run more boost with a vtec i said "build" the mini me as in rebuild the bottom end and that means you can run more boost. I was going to do the T3, hf/std manifold with custom adapter, downpipe, find an intercooler, custom i/c pipeing, 1g dsm b/o, S-AFC controller, and maybe 1g injectors. it'll just take longer to get all the pieces together and i will already have the head if i get the crx, that will just be easier. also i need a good daily driver. so im still undecided as of yet.
Old 07-11-2003, 06:26 PM
ummm.....dont listen to this guy just boost the a6, they are strong motors, you'll be happy, if you want to build the mini me then make sure you know what your doing......ive seen some mini me's produce great numbers but others produce shyt numbers.....
1991 Honda Crx Si
Old 07-11-2003, 06:32 PM
ok i just read the drop shop stuff and alll i can say is OOOOOOHHHHHHHH!!!!!. Ok going turbo when i get the head ill post a thread to sell it on here first. ill prob go for a trade with some stuff on it too. ill let you guys know.
Old 07-12-2003, 12:19 AM
amy@af's Avatar
i'm glad it was help feel free to e-mail dropshop (jon). tell him ami sent you to annoy him
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
