Old 03-08-2004, 04:27 PM
paulsenior paulsenior is offline
85 S-10 Blazer Problems
I Have two problems with my blazer. One My left head light goes out occasionally. Two My clutch makes a clicking/ rattleing sound when the peddle is pressed. can anyone help me with this?
Old 03-08-2004, 08:12 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 85 S-10 Blazer Problems
check the wiring and the plug socket it's probably coroded. clutch noise could be a few things most likely bad release bearing. does the pedal bounce/pulsate when light pressure is applied? if it does you might have a warped flywheel/ warped clutch disk/ bad pressureplate diaphram
1996 S-10 Blazer DTC Problem (P1192) arthurjohn Problem Diagnosis 17 02-16-2010 07:09 PM
1989 S-10 Blazer Wiring Diagram 89S10Blazer S-10 1 01-07-2010 10:01 AM
2001 S-10 Blazer problems FiXxXeR57 Blazer 21 03-10-2005 03:41 PM
s-10 blazer problems budwzr Blazer 10 02-19-2005 01:09 AM
'88 s-10 blazer problems blazer_boi S-10 9 09-05-2004 12:06 AM
