Old 02-15-2005, 08:09 PM
budwzr budwzr is offline
s-10 blazer problems
94 s-10 blazer died would not restart unlill i let it sit for 15 min or so then died right away. if i let it sit for about 1 hr it may run for couple min. let it set overnight and it will run for about 15 or so then die and not restart unles i let it sit. these times are about the same times on every restart and senerio. i can here fuel pump running when i turn on key. i replaced fuel filter but same thing happens. are there anythings besides fuel pump to check into.
Old 02-15-2005, 10:33 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: s-10 blazer problems
When it dies, check to see if there is spark from the coil.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-17-2005, 01:14 PM
Cam1959 Cam1959 is offline
Re: Re: s-10 blazer problems
coil could be shorting (jumping between wires) out inside it's many windings, putting out lower current then shorting completely from this arcing heating it up and shortly completely. sometimes you can hear it if you put your ear close. sounds like faint clicking. i had one on other vehicle that ran ok with no load on engine. but trying to accelarate fast or climb hills on highway put extra load on cylinders that reduced spark couln't handle i guess. you can get those cheap pencil thingies with rounded end and light, to hold against ignition wires to easily check for current flow there.
Old 02-17-2005, 04:25 PM
BlazerLT's Avatar
AF -Advisor
Also, in complete darkness, open the hood and look for the coil arcing to something.
It will look like blue sparks.
Old 02-17-2005, 11:57 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
may sound really dumb to some people, but to others its not commen sence, if you do happen to see the spark, dont touch it! you will become the ground and get one hell of a shock, ive never done it personally but i did watch one of my dumbass friends do it one day on his full size chevey, best repair ever
Old 02-18-2005, 12:00 AM
BlazerLT's Avatar
AF -Advisor
Thread moved to the blazer forum.
Old 02-19-2005, 01:40 AM
diddy0071 diddy0071 is offline
Send a message via MSN to diddy0071
um yeah, that isn't any joke. DO NOT, I REPEAT, DO NOT TOUCH THE COIL. SEVERE INJURY, OR DEATH CAN RESULT. NO B.S. (this is coming from a person with their Associates in electronics, and someone with common sense as well)
"I'm a jerk, not an asshole!!"
Old 02-19-2005, 01:49 AM
o i wasnt joking, my buddy really did touch it, he couldnt feel his left arm for over a day, the doctors told him he was lucky that we were inside on a dry floor or he could of been in for much worse... but ever seince then he hasnt assumed im a cautious know it all when it comes to fixing something, he listens, pretty good too... its no joke or laughing matter, there is quite a kick in the ignition/fire system on vehicals
Old 02-19-2005, 01:51 AM
I didn't think you took it as a joke, but many people reading the forum might. it's dangerous, and many people should be cautious.
Old 02-19-2005, 02:01 AM
the ones i like to wait and watch are the people who think they battery being unplugged is a joke and they are the ones who alwase seam to have a ring or some form of metalic jewlry on, people dont realize how dangerous this stuff can be, and they will ignorently take the risk of e.s. so they dont have to reset their clock and re do their presets
Old 02-19-2005, 02:09 AM
True true. Leaving the Ground connected is asking for trouble. Another thing, is using a ratchet near the battery, without having the ground disconnected. I saw a guy working on his car once, who didn't disconnect the Negative terminal, and accidentally touched the ground and the power terminals with the ratchet at the same time. needless to say, he was hospitalized, but very lucky. the battery blew up, (it was old) and he didn't get anything in his eye. I disconnect the whole battery period when working on or near the engine, and remove it from the car. It's more work than necessary, but better safe than sorry.
