Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-08-2004, 12:40 PM
Daniel Flamini Daniel Flamini is offline
Brake lights fuse blown
Can anybody give me a hint on what to do? I keep blowing my brake lights fuse. Every time i touch the brakes, the fuse blows instanty. I did notice the other day, before this problem, that when I put my brakes on my front turns signals would light up. Any deas would be appreciated
thanks
Dan
Old 03-08-2004, 02:23 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Brake lights fuse blown
If you happen to have a trailer wiring harness, try unplugging it and see what happens. This is the common cause for blowing fuses.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-08-2004, 06:26 PM
Dan106 Dan106 is offline
Make sure you check the brake light switch on the brake pedal. This switch activates the second you put pressure on the brake pedal. Check to make sure that it is not grounding out as you put pressure on the pedal. This would cause the fuse to blow if it is grounding out.
2004 Sentra 1.8S-No brake lights?!? brynfrt05 Sentra | 200SX (USDM FWD) 11 06-08-2010 09:30 AM
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 07:38 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
