Old 03-07-2004, 04:59 PM
indyfan indyfan is offline
Send a message via Yahoo to indyfan
1995 Plymouth Voyager Minivan --HELP
I need help with my 1995 Plymouth Minivan. It does not want to run, it spits and sputters, you can smell gas fumes, it gets like a mile to a gallon on gas. We tried to replace the fuel filter, new spark plugs, new plug wires, new distributer cap, new roter button, and new pick-up ground plate. Nothing had changed. Thanks in advanced.
P.S. I had it checked out and it showed on a compter code 62. Does anyone know what this means?
Old 03-08-2004, 11:34 PM
Anaudiophile Anaudiophile is offline
Re: 1995 Plymouth Voyager Minivan --HELP
First of all......there's no such code. Codes end at 55.
I assume it's a 3.0L seeing you've replaced some distributor parts. Sounds like you have spark knowing that it does run.
Get the fuel pump pressure checked and test for leaks ie. fuel injector leaks. Of course checking for external type of fuel leaks is a given!!
98 Plymouth 2.4 camshaft position sensor goatfan Caravan | Voyager 0 07-07-2010 01:18 AM
1995 plymouth voyager 3.0L littlebitofinsanit Caravan | Voyager 2 02-27-2010 01:58 PM
1998 plymouth voyager need help fast and out of ideas pdragonz Caravan | Voyager 14 07-30-2009 12:06 PM
1995 PLYMOUTH VOYAGER issue scj6771 Caravan | Voyager 5 11-22-2005 07:14 PM
help.. how to programming a remote keyless 1995 plymouth Voyager gomezsydney Caravan | Voyager 5 04-22-2005 12:50 PM
