Go Back   Automotive Forums Car Chat > Toyota > Solara
Old 03-07-2004, 02:58 PM
linnibin linnibin is offline
Send a message via AIM to linnibin
2000 solara headlight condensation
I have terrible condensation in one (sometimes both) headlights. How can I remove them to dry them out? I never had this happen on my 98 Camry, so is this normal....it has been heavily raining lately.
Thanks.
Old 05-05-2004, 12:18 AM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: 2000 solara headlight condensation
It's not usually normal, what causes this is when the seals that go between the clear plastic part and the backing of the light break down, therefore letting moisture in. You need to remove your corner lamps by removing the retainer clip by the fender on each side, and there will be two bolts on top holding your lamps in, and one on each side behind where you took the signal lamp out, remove all three and take the lamp out. You can seperate the lenses from the case by turning your oven on for about five minutes to 350 and after the five minutes, turn it off, place each light on a baking sheet for 6-7 minutes with foil underneath and seperate the lights. Wipe them out and clean them, and press them back together.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
2000 Solara Brake noise fnemeth Solara 1 09-17-2004 04:02 AM
Drivers side headlight - condensation? rodgerturner Venture 3 07-10-2004 01:28 AM
2000 Solara question marinierb Solara 3 06-03-2004 10:05 PM
2002 civic headlight condensation civicrob Exterior | bodykits | Lighting 1 01-14-2003 12:22 PM
help removing headlight condensation 94cam Integra 0 05-05-2002 06:44 PM
