Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 06-19-2004, 03:52 PM
rodgerturner rodgerturner is offline
Drivers side headlight - condensation?
Somehow at some point water had gotten into my headlight assembly. It condenses and foggs up the headlight - - looks awful to me although the headlight still works fine.
I've noticed that on a few other Ventures - same side....anyone else have this?
A replacement from GM is outragous...upwards of $140...I've seen them on Ebay for about $60-80, anyone try these? Do they look OK?
thx
RT
Old 06-26-2004, 10:34 PM
jac1028 jac1028 is offline
I have a 2000 Venture and water gets into the headlight too. Fills so bad I have to disassemble the headlight area and drain the water out after a few rain showers. Headlight works fine though, I ain't fixin what ain't broken.
P.S.
Does your venture loose oil somehow, I don't know where my oil is going, clean coolant, no leaks, exhaust ok. I have to add a quart like every 2 weeks.
Old 06-28-2004, 04:20 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Drivers side headlight - condensation?
my driverside did that....heres what i did...
1/8" drill bit. Drilled hole in bottom most spot on the headlight. Still gets water in it, but now it drains out!
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 07-10-2004, 01:28 AM
TweakedGM TweakedGM is offline
If those are sealed head lights I would dry it out then where the lense is press on to the back use goop, glue or some type of sealent.
