Old 03-07-2004, 07:27 AM
chariot_gdi chariot_gdi is offline
Question Primer
Can the tamiya primer we use for plastic bodies be used on photetched metals?
There's another primer by tamiya which is specifically for metals but do i really need it since the usual primer is said to be for plastic and metal?
thx
Old 03-08-2004, 06:51 AM
Old 03-08-2004, 09:16 AM
Vric's Avatar
Vric Vric is offline
Re: Primer
normal tamiya primer will do the trick
Old 03-08-2004, 10:05 AM
Ken B. Ken B. is offline
Send a message via AIM to Ken B.
Re: Primer
Yep, I can vouch that any Tamiya primer will work on PE, gray, white, or the metal-specific stuff. I've used all 3.
Old 03-08-2004, 02:05 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
You should prob. scuff the PE with fine sand paper and clean it with lacquer thinner before priming and painting it.
The metal primer is intended for 'white metal' and I'm not sure it would work any better on stainless steel.
SCCA 7, The lost Z
Flat base clear gloss coat? White primer Grey Primer? AllAlone.Gz Car Modeling 4 12-25-2006 06:42 AM
Filler primer or self etching primer? Lances133 Cavalier 3 11-13-2006 03:20 PM
whipe on primers vs spray on primers ky0 Car Modeling 14 01-31-2006 05:53 PM
Whats the difference between Tamiya Grey Primer & Modelmaster Grey Primer? chubbs36chambers Car Modeling 31 02-14-2004 08:56 AM
white primer over grey primer v12horse Car Modeling 8 08-22-2003 08:54 PM
