Old 03-07-2004, 02:07 AM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
cam seal help
okay so my car has this nasty oil leak and im driving home from work and snap there goes the timing belt well turns out my head is fine because of the 1.6 pistons i used i need to know how to change the cam seal i know i have to remove the valve cover and remove the cam pulley but what else
Old 03-07-2004, 08:12 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
You'll need a seal puller or flat blade screw driver. You pry out the old one and press in the new one (be careful not to nick the cam). You can use a large socket as a seal driver. GL
Old 03-07-2004, 10:16 PM
Re: cam seal help
it was alot easier then i expected all went well and now i dont leave puddles wherever i park but i accidentally put my belt on worng and now its a tooth off but it runs i'll fix that tommorow
Old 03-08-2004, 10:21 PM
johnb16a2's Avatar
Re: cam seal help
Glad to hear things worked out. Great job.
Cam seal, crank seal, water pump questions f100240 Metro 6 12-17-2007 03:24 AM
Oil Leak - Cam seal replacement climber211 '97+ 5 11-28-2005 07:42 PM
Question About Cam Seal 2crunk Off-Topic 4 03-05-2005 11:14 PM
Got my cam seals........$12.95 woo hoo CBURKE Integra 8 02-03-2005 10:15 AM
cam seal salchichon20 Engineering/ Technical 3 06-15-2004 12:37 PM
