Old 03-05-2005, 01:07 PM
2crunk's Avatar
2crunk 2crunk is offline
Exclamation Question About Cam Seal
My question is that, how hard would it be to replace the cam seal? What all do you have to remove or take apart to reach it? Thanks in advance!!!
Check out more pics and info on my Stang at: http://www.cardomain.com/profile/2crunk
Rest In Peace Hypsi87, you'll be missed.
Old 03-05-2005, 02:06 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Question About Cam Seal
year make and model in your sig. im guessing that you arent asking us about your mustang's cam seal
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 03-05-2005, 02:08 PM
2crunk's Avatar
Sorry about that, a '95 Eclipse N/A 420a.
Old 03-05-2005, 04:36 PM
2crunk's Avatar
Well i looked in the Haynes manual and identified where they are, and what is happening is that the seal around the rear cam is getting pushed out of place. You can literally push the seal back into the housing with a screw driver. My question is why do you think it is doing this? Were they installed incorrectly or is something forcing them out?
Old 03-05-2005, 11:14 PM
kjewer1 kjewer1 is offline
AF - Advisor
Excessive oil pressure can force them out, or a loose or imporoperly installed seal. I've had them leak on initial startup after building my first motor. Its one of those mistakes you only make once The trick is that you have to fuss with the timing belt to get the gear off. HAving a NT, I cant offer much advice since I've never done a tbelt on those motors. But on the turbo motors there is a trick to doing this without having to do a whole tbelt job essentially. But if your mileage puts you near a tbelt service anyway, now is the time to do it! OTherwise figure out how to deal with that belt and just fix that seal. I would replace it, just to avoid having to do this job twice. They are cheap, 7-10 bucks I'd guess.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
