Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 03-04-2004, 12:31 PM
tomdean23 tomdean23 is offline
Oil Pump
I own a Porsche 944 1986 2.5 Lux and have just suddenly lost all oil pressure. The car has always taken a while to build pressure when first started but held 4-5 bar when driving. The pressure fell all of a sudden and so I think it is the oil pump that has failed. Does anybody have any ideas if I might be right or if they can think of any other reason for this fault. I would also like to know if it is possible to replace the oil pump without removing the engine, and if you have any tips for doing it.
Cheers
Tom
Old 03-05-2004, 03:07 AM
87Porsche951's Avatar
87Porsche951 87Porsche951 is offline
Re: Oil Pump
Oil Pickup, leak, pump, etc
Old 03-05-2004, 05:28 AM
930guy 930guy is offline
Re: Oil Pump
Use a mechanocal guage first t be sure that the sender did not fail. I 've seen that happen before
Old 03-10-2004, 04:28 PM
Re: Re: Oil Pump
Sender has not failed, no oil getting to tappets, does the engine have to come out to replace the oil pump? And where do I find the oil pressure regulator?
93 bird 3.8L oil pump replacement issues capndoodoo Thunderbird 1 03-27-2009 08:20 PM
1.8t oil light turbo problem or oil pump deadkat '94 - '01 0 07-12-2004 10:47 AM
Removing oil pan to change oil pump?????? OzzyMamma Dakota 1 04-21-2004 02:18 PM
possible oil pump problem ,slow oil pressure on cold engine 71chevydude C/K 0 03-22-2004 04:11 PM
Bad Oil Pump? No oil in valves? hgallegos915 Cavalier 6 03-13-2004 11:34 AM
