Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-07-2004, 05:42 PM
OzzyMamma OzzyMamma is offline
Exclamation Removing oil pan to change oil pump??????
[color=darkslateblue][font=arial black][size=3]
Question: I need to change the oil pump in my '01 Dakota. To remove the oil pan do I need to pull the engine or drop the front end? Or will it come off without doing either of these? Please Help!!
Thanks
Ozzymamma
Old 04-21-2004, 02:18 PM
dakotafixer dakotafixer is offline
Re: Removing oil pan to change oil pump??????
Just replaced one in a 2001... You will have to partially unbolt the front differential and let it hang, also you will have to remove the steering rack and pinion, then you can remove the oil pump. (Of course you will have to remove the oil pan also.)
Oil Pan Gasket? ken_man_1 F Series 8 12-03-2010 07:30 AM
Oil pan Change on 2000 Ford Ranger jpmwjm Ranger | Courier 1 04-02-2005 09:30 AM
96 F150 oil pan change jdkurt F Series 1 11-12-2004 08:54 AM
