Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-03-2004, 07:27 AM
rodam rodam is offline
Back-up lights won't work
Hey all, I'm having a problem with my back-up lights and I read a post from someone who had the same problem with their '97. They said that they thought it was the back-up switch. 2eyefishclaw responded that it was on the tranny. 2eye, if possible could you tell me exactly where it is? Is it easy to get to without pulling the transmission? PLEASE say yes. As always thanks in advance for any help y'all can give me.
Old 03-03-2004, 01:15 PM
Dan106 Dan106 is offline
Re: Back-up lights won't work
The last time I replaced the backup light switch was on a 86 Isuzu pickup. If your vehicle is a standard, it should be located on top of the transmission, where the shifter enters the top of the case. When put into reverse, the shifter activates the switch. If you have an auto sorry I can't help.
Old 03-03-2004, 08:17 PM
Thanks for the info, I found the back-up switch and replaced it, but the lights still don't work. Does anyone have any other ideas as to what it could be?
Old 03-03-2004, 09:01 PM
geg geg is offline
Step one would be to hot wire the supply side of the circuit at the switch. This will tell you on which side of the switch you will need to chase down the problem. Did you check the bulbs and fuse?
Good Luck
95 Grand Caravan back up lights won't work bdeaner Caravan | Voyager 3 07-16-2007 05:07 PM
'93 dodge caravan back up lights won't work hector991 Caravan | Voyager 6 03-04-2006 12:59 AM
back up light don't work, Day time light don't work. dans82vette Ram Pickup | Ram SRT10 0 01-27-2006 11:19 AM
96 Camry Back up lights not working arysr Camry/Camry Hybrid/Vista 1 04-30-2005 07:47 AM
Back-up lights won't go off! GenieNChains Lumina 1 02-12-2005 10:27 AM
