I've changed the bulbs and checked the fuses, but the back up lights still will not light up when I'm in reverse. Where do I go from here to correct this problem?
Re: 95 Grand Caravan back up lights won't work
The neutral start safety switch controls reverse light function. Here's how to test it. http://www.autozone.com/az/cds/en_us...rInfoPages.htm
I've read the switch is less than $20. Could just be a loose or corroded connection. The shift linkage needs to be adjusted correctly for the switch to work correctly. If your van will only start in park or neutral then it's a good bet the linkage is adjusted properly.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
We have the same problem, only it appears that our model (98) has the switch for the back-up lights actually ON the transmission. The mechanics who discovered that for us didn't charge us for the 4 hours of work they did trying to figure that out, but they were quite irritated. I called an AAMCO and they said it would run anywhere around $400 just to get at the switch, assuming that's the issue.
My best suggestion if your switch is in the same place-move to Jersey, you don't need back-up lights to pass inspection.
tsyzer Your fix would cost $400 because your switch is inside the tranny. Assuming you have the 4 speed you have to partially dismantle the tranny to get at it.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm Move to Jersey? You've...well, I'll leave it be.
