Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-03-2004, 02:30 AM
mrpontiac mrpontiac is offline
jumper out the clutch switch
Which wires do I need to connect to jumper out the clutch switch on a
96 ranger. I have no power to the solenoid, but the solenoid does work
(it is new along with starter). I'm trying to determine if it is the clutch
switch or the ignition switch that is bad. When key is turned to the on position then jump the solenoid the engine will start and run.
Thanks
Mike
Old 03-05-2004, 03:34 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: jumper out the clutch switch
white/pink & D blue/orange
Old 03-07-2004, 02:19 AM
Thank You
can't figure out why the engine still revs even after i put in the clutch. sokaplaya21 Cougar 1 12-04-2010 07:58 PM
Bypassing the ignition clutch switch. 94Z32XTT Cavalier 4 11-29-2004 08:38 PM
Klunk when letting out the clutch in gear Hemi man Integra 3 10-17-2004 01:12 PM
Disconnecting the clutch start switch 97GSTspyder Off-Topic 6 01-21-2004 05:49 PM
