Old 11-28-2004, 09:10 PM
94Z32XTT 94Z32XTT is offline
Bypassing the ignition clutch switch.
I looking at installing a remote car starter on my standard 97 Cavalier and need to bypass the ignition clutch switch. Has anyone done this before and have any info on it? Thanks!
Old 11-29-2004, 03:05 AM
Re: Bypassing the ignition clutch switch.
You should be able to bypass the clutch switch. I have a 300zxTT and it does not have this feature. You can start it without the clutch pressed. I also am in a habit of always leaving it in neutral after parking inorder for my turbo timer to run after I remove the key from the ignition.
Old 11-29-2004, 12:07 PM
sirk798 sirk798 is offline
Send a message via Yahoo to sirk798
Re: Re: Bypassing the ignition clutch switch.
Originally Posted by Classicrocjunkie
You cannot put a remote car starter on your standard... plain and simple... Not worth all the hassel man. Hows it going to start with the clutch enguaged?
you are so wrong, sidewinder makes a standard tranny adapter for use with remote start... best buy used to sell em when they sold sidewinder products.... a friend of mine has a 99 mustang with standard tranny, and a remote start.... done the right way....
Old 11-29-2004, 02:04 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
While i thought other wise b4.... i will stand corrected.... Guess technology has come along way in the past few years... when i tried to get one installed on my G/F's car i was told not possible by 3 aftermarket installtion shops... but after doing some quick reaserch i have found some info i didn't know..most manual transmission remote car starters require a signal input for clutch bypass and a e-brake wire. When this is combined the unit enters reservation mode, meaning you drive the car into the driveway, tap the brake, pull on the e-brake, remove the keys (car stays running) open and close the door (checks for a signal fromthe doorswitch) and then you turn the vehicle off by using the remote. Now the remote starter knows that the vehicle is in neutral and all the safety checks are in place to allow it to remote start properly and safely. While i've been searching for an actual device they are few and far between and i approached the same places for install and they said they do not install them becuase of the liabiltiy of the device messing up your ignition due to the driver leaving the car in drive... while i am not sure about that... its will be hard to find a place to do it, let alone do it yourself... also they are not exactly leagal meaning they won't pass state saftey inspections
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 11-29-2004, 08:38 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Yes, you are correct but forgot to add something. If you open a door, you gotta go through the hoops again to remote start it.
Also, Sidewinder never sold any such thing nor did DEI, the parent company did either. I know, I was a Sidewinder dealer for many years until I started my own shop. The part you are talking about is called a SPDT Relay. All it does is bypass the clutch switch. It is nothing special. The quick easy way is just to unplug the switch at the pedal but not recomend it. I will install on manual cars but I make sure to hook into the E-brake and also add a digital tilt sensor. What it does is "reads" the angle that the car is parked and sets itself then to go off if the car is rocked ever so slightly. So, if you leave it in gear and it starts to move, it stalls out.
Also, some vehicles actually have a neutral switch like motorcycles. It's just that many people do not know this.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
