Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 12-04-2010, 08:57 AM
sokaplaya21 sokaplaya21 is offline
Exclamation can't figure out why the engine still revs even after i put in the clutch.
I just purchased a 2000 mercury cougar about 8 months back in south carolina. I moved to New Hampshire (much colder) about 4 months ago. I didn't have this problem when i was in south carolina. However since about a month and a half ago, everytime i push in the clutch to change gears the rpms go up. i just changed all of my O2 sensors, i took out the performance chip i had in the car, gave it a tune up (new spark plugs, new fuel filter, new wires), and a new starter.
also the radiator light is on and i can't figure out why. i replaced the reservoir cap because this car doesn't have a radiator cap.
The ABS light is on,and again i don't no why. I no the previous owner put on after market racing brakes, pads, and rotors.
Old 12-04-2010, 07:58 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: can't figure out why the engine still revs even after i put in the clutch.
I wonder if you have icing inside the throttle body, which is preventing the throttle blade from closing fully when you release the gas pedal during an extended drive.
The cooler, damper NH weather is partly responsible. Also the radiator problem may be related, if there is a problem that allows the engine to run too cool.
Finally, if the previous owner modded the car, he may have installed a "cold air intake" system which might be contributing to the problem. Ask him or her if he did this and if so, does he have the stock one lying around. If yes, get it and put it back on.
I can't figure out why my Ford won't run! Gremson Classic Cars 7 12-11-2009 03:46 PM
Car is running rich, can't figure out why... HighMileage230000 Riviera 3 01-15-2009 06:17 PM
Can't figure out why my fans want come on without the AC being on annabell Windstar 3 04-15-2005 11:28 PM
Truck lags can't figure out why. Need help. sanattof Silverado 2 11-11-2004 11:51 AM
Im runnin' hot Can't figure out why Civicsiassasin91 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-18-2003 03:04 PM
Tags
2000 , assist , cougar , mercury
