Old 03-02-2004, 12:52 PM
wotsie wotsie is offline
raidator fan on 97 cavalier
The fan comes on when I turn a/c on but when a/c is not on the fan does not come on even when engine heats up.
Thanks aj
Old 03-03-2004, 07:59 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: raidator fan on 97 cavalier
the engine has to get pretty hot before the fan kicks in. check the fuse and relay. to get the fan to kick on you need to rev the engine for a few minutes untill the gage gets about midway.
Old 03-03-2004, 10:06 PM
hopeless4life hopeless4life is offline
Send a message via MSN to hopeless4life
It does have to get pretty before the fan kicks in. The best way to check this is hotwire your fan for a second just to see if it works. If it does then your probably looking at an Engine coolant temperature sensor (ECT). Its located in the thermostat housing. You test this with an ohm meter. You unplug the sensor connector and probe the sensor tips. You should have high resistance when the engine is cold and low resistance when the engine is hot. I've seen several of these vehicles have this problem and the sensor was the problem.
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
cavalier 99 cooling fan drtyrocker Cavalier Problem Diagnosis 3 07-01-2009 08:08 PM
2001 Cavalier hizkid42 Cavalier Problem Diagnosis 2 03-07-2009 08:20 AM
1996 Cavalier Douglas91 Cavalier Problem Diagnosis 7 02-21-2009 06:53 AM
Raidator fan Relay cplbuddy Caravan | Voyager 1 07-09-2007 11:34 PM
