Old 02-26-2009, 10:30 PM
hizkid42 hizkid42 is offline
2001 Cavalier
2001 Cavalier 119,00 miles 2.2l engine. Engine hiccups and shudders at any speed, worse around 40 or 45 mph or above when the engine is warm. Have replaced plugs, plug wires, taken to several garages including Chevy dealer. Not throwing any codes when hooked up. Used fuel injector cleaner and injectors have been checked and ok. Fuses are okay. Serpentine belt is fine. Dealer replaced a connector and it is no better. Does not stall out but scary to ride in. Any ideas? Dealer noticed that sometimes some of the cylinders were not firing but ???? how to fix.
Old 02-27-2009, 05:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 2001 Cavalier
I'd start by checking the ignition module and coil packs... The dealer didn't check those?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-07-2009, 08:20 AM
Re: 2001 Cavalier
I know that the dealer checked the ignition module but not sure about the
coil packs. I will check. Thanks.
Tags
2001 cavalier , hiccups , shudders
