Go Back   Automotive Forums .com Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 03-01-2004, 09:44 AM   #1
mdavis123
Question gas pedal sticking on '01 4cyl.
Has anyone had a problem with the gas pedal/cable sticking when cold?
For now, it only sticks in the idle position. The dealer hasn't heard of the problem before.
Thanx.
mdavis123 is offline   Reply With Quote
Old 03-01-2004, 01:00 PM   #2
HONDA_99
Re: gas pedal sticking on '01 4cyl.
it doesn't matter if dealer heard about these problems or not they obligated to fix it under warranty (if your car still under warranty). if you feel dealer trying to avoid you until your car's warranty is out, you can call Honda's customer service and file complain, Honda dealer don't like when customer do that.
if you're not happy with current dealer you can always use any other Honda dealer.
Power: Denso IK22 spark plugs, OBX Headers, J32A2 Camshafts, CT SC w/HB
Electronics: Apexi VAFC (untunned)
Gear Box: Rebuilt at 53K ml & at 63K ml by Aamco and still
Suspension: Eibach Sportlines, Koni Sport, Comptech Sway Bars & Neuspeed upper strut bar.
Wheels: 17x7 OZ Racing Superleggara & 215/50 Dunlop Sport A2
Brakes: Legend GS 2 Piston Calipers, Goodridge SS Lines, Endless Nova Pads
HONDA_99 is offline   Reply With Quote
Old 03-01-2004, 06:58 PM   #3
mwkirchner
mwkirchner's Avatar
Thanx.
In defense of your dealer ... there is a bulletin out about this issue ... but it does not apply to your car. It still is what is wrong with your car though.
Tell him to look at bulletin #01-004 Throttle Body Cleaning.
We have to do this cleaning on a lot of the cars that pass through our dealership. I am not sure why Honda has not made this bulletin apply to the later vehicles ... but they still have the same issue as the ones that the bulletin covers.
Here is an excerpt from the bulletin:
SYMPTOM
When the engine is first started after the vehicle has sat overnight, customers may “feel” the release of the throttle plate through the accelerator pedal. Some describe it as a one-time “pop” sensation.
Customers may have trouble explaining this phenomenon because:
• They can’t repeat it because it only happens one time, when the engine is cold.
• The accelerator pedal works normally at all other times.
• There are no other symptoms.
• It may be intermittent, happening only during cooler weather.
PROBABLE CAUSE
The symptom is caused by normal buildup of contaminants in the throttle bore, combined with expansion and contraction of the throttle body.
CORRECTIVE ACTION
Partially remove the throttle body, and clean it with Honda carburetor cleaner or throttle plate and induction cleaner.
I can guarantee you that if he does this ... you will no longer feel that sticking in the morning (for a while that is).
mwkirchner is offline   Reply With Quote
Old 03-02-2004, 09:43 AM   #4
mdavis123
Thanks! I had trouble trying to figure out the sticking point. The cables and pedel seemed ok, but the sticking sensation isn't noticable when turning the throttle by hand at the t.body.
thanks again.
Old 03-03-2004, 02:11 PM   #5
chrisb0426
I have had this problem every winter. The dealer charges $75 to fix it. They tell me this happens when the local refinery changes it's mixture from summer blend to winter blend. I am sure it would be easy to fix it and am too lazy.
chrisb0426 is offline   Reply With Quote
Old 03-03-2004, 02:33 PM   #6
mdavis123
So a can of carb cleaner, an adjustable wrench, and a six pack of beer, and I'm good to go! ;-)
Gas pedal went to the floor on its own! bagem788 Traverse 8 11-08-2017 07:08 PM
2000 Sonoma Gas Pedal on floor but no acceleration timaugie Sonoma | S-15 0 07-29-2009 03:25 AM
gas pedal sticks durangodriver Blazer 16 11-01-2005 02:38 PM
gas pedal sticking and brake pedal making weird noise? 00'GMCYukon Yukon 3 05-11-2005 09:40 PM
tacoma gas pedal sticks on take off kflagg Tacoma 4 04-05-2004 04:11 PM
