Old 02-29-2004, 11:13 PM
ajdragonf's Avatar
ajdragonf ajdragonf is offline
Send a message via AIM to ajdragonf Send a message via Yahoo to ajdragonf
Exclamation BIG Idle problem...NEED HELP!!!
My 94 Accord EX 5sp. is having a HUGE idling problem. For the last couple of weeks, the car has been idling at around 1200 RPM'S!!! It will jump anywhere from 1200-1700 (up and down) for a period of time when in neutral, or when the clutch is in. What the heck is going on? It's getting pretty annoying, especially when the car is SUPPOSED to idle at around 660-750! Please help!?
ajdragonf kicks it
Here's a pic of my car: [img][/img]
Old 03-01-2004, 07:24 AM
Hondaman56 Hondaman56 is offline
This does this only when its cold outside? If so, its a bad thermostat. I had this problem for 5 years before I figured it out. Its an easy enough and inexpensive enough fix.
Old 03-01-2004, 07:56 AM
ajdragonf's Avatar
Re: BIG Idle problem...NEED HELP!!!
I'll give it a shot and see what happens. I'll let you know!!!!
ajdragonf kicks it
Old 03-01-2004, 06:01 PM
mwkirchner's Avatar
mwkirchner mwkirchner is offline
I think what you are experiencing here is a bad IDLE AIR CONTROL VALVE ... or IAC MOTOR as it can sometimes be known.
Old 03-01-2004, 06:34 PM
ajdragonf's Avatar
Yep, you're right. I checked around before messing with the thermostat and found that I needed to cap off one of the vacuum hoses hooked up to the original air intake assembly/filter. Fixed the problem in 2 seconds flat.
ajdragonf kicks it
REALLY bad Idle problem Need Help Zanark 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 05-04-2005 08:06 AM
Idle problem-need help! klone420 Probe 3 01-03-2005 10:49 PM
Engine Idle Problems Need Help Please!!! sgetts Taurus | Taurus Wagon 1 09-20-2004 07:34 PM
rough idle problem - need help beetlejuice69 Let's get Technical! 4 08-29-2004 07:55 PM
idle problems.. need help stock1.5 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 11-06-2003 11:15 AM
