Go Back   Automotive Forums Car Chat > Ford > Probe
Old 12-26-2004, 12:23 AM
klone420 klone420 is offline
Question Idle problem-need help!
91 probe-when the car is in park it idles at 1500-2100. when you put it in gear its normal-less than 1000. What do you think the problem is & what can I do to fix it? A machanic used the Idle control to fix it but nothing happened. Also, the stearing wheel shakes when stoped at a traffic light, why is this?
Thanx for any help!
Old 12-26-2004, 10:32 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Idle problem-need help!
lol i have the same problem, im gona go clean my throttle body tommorow, its probably carbon build up on the throttle plate, its sucks, if not im guessing its sensor related, i got a check engin light that comes off after i get abover 2300 rmps, i dont no i lazy tho, and my car is screwed my pistons rings are going so i might leave it, kina lost intrest in the damm things...
1
Shift_BOOST
97 s14
Old 01-01-2005, 01:53 PM
jtecj jtecj is offline
Send a message via AIM to jtecj
Is it an automatic? If so it could be a tranny sensor
Old 01-03-2005, 10:49 PM
turbo2nr's Avatar
Re: Re: Idle problem-need help!
it turned out to be a oil build up on the throttle plate, my turbo seals are gona causeing oil to leak into the motor, so it sucks,
1
Shift_BOOST
97 s14
