Old 11-01-2003, 04:09 PM
stock1.5 stock1.5 is offline
Exclamation idle problems.. need help
im having problems with my idle in my hatch. i was sitting @ a light when my car started to "bog out" then all of a sudden my idle jumped to 2000rpm and now it wont come down. ive taken it to 4 shops and noone knows what is wrong. the oxygen sensor is fine, my throttle cable is fine, ive removed and cleaned my throttle body, my butterfly is not bent, and the spring recoils fine, but when i push on the butterfly it retards the rpm. what could it be??? its really pissing me off. so should i just buy a new throttle body all together? how do i check for a leak that could be messing up my vaccuum?
IM RICK JAMES BITCH
Old 11-01-2003, 07:37 PM
BullShifter's Avatar
Re: idle problems.. need help
1. make sure idle is set correctly & throttle cable not over-tight.
2. EACV - electronic air control valve
3. vacuum leak
http://www.binghamtonlife.com/manual..._emissions.htm
Old 11-01-2003, 08:29 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Re: idle problems.. need help
Check your TPS (throttle position sensor)
Check out my car here My 91 Hatch
Old 11-03-2003, 12:54 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Try checking the Frequently Asked Questions at the top of this forum or even do a search. This topic has been done to death
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 11-03-2003, 03:29 PM
BlueCivic83's Avatar
BlueCivic83 BlueCivic83 is offline
Send a message via AIM to BlueCivic83 Send a message via Yahoo to BlueCivic83
chek this out
http://www.binghamtonlife.com/manual.../91-11-130.jpg
Old 11-03-2003, 08:14 PM
Originally Posted by BlueCivic83
is that for d series engines or b series? because i have b16 and it doesnt look like that
IM RICK JAMES BITCH
Old 11-03-2003, 11:42 PM
Those are D series in that manual
Old 11-05-2003, 11:09 AM
is there a reference book for a b16/ and if so how do i get one?
IM RICK JAMES BITCH
Old 11-05-2003, 01:28 PM
www.helminc.com or I'll post a site when I get home with many online repair manuals, I'm sure a B16 is on it . . .I don't know for sure.
Old 11-06-2003, 11:15 AM
got the edelbrock 65mm itr throttle body and my problem was solved. bad tps caused my idle to jump. all is good now and the car is a little more throaty with better throttle response. i like it and wouldnt mind the victor x intake manifold to match. thanks for all the help!
IM RICK JAMES BITCH
REALLY bad Idle problem Need Help Zanark 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 05-04-2005 08:06 AM
Idle problem-need help! klone420 Probe 3 01-03-2005 10:49 PM
Engine Idle Problems Need Help Please!!! sgetts Taurus | Taurus Wagon 1 09-20-2004 07:34 PM
rough idle problem - need help beetlejuice69 Let's get Technical! 4 08-29-2004 07:55 PM
BIG Idle problem...NEED HELP!!! ajdragonf Accord/TSX/Accord Hybrid 4 03-01-2004 06:34 PM
