Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-01-2004, 12:10 AM
maxiG20 maxiG20 is offline
rpm all over the map
guys,
Lately while driving in neighborhood streets my 92 max (with 131000miles) rpm starts pulsating and going up and down between 0 and 1200 2-3 times and then naturally stalls and it won't start again untill i give it a boost and let is run at about 2000/2500 rpm for few minutes. even then it might stall again few minutes later.
I have to say that this does not happens everyday, but now it is becoming more frequent.
Any ideas? please help?
Thanks
PS, my ABS light comes and goes sporadically as well, i wonder if that has anything with this, causing some electrical glitch?
Old 03-01-2004, 12:59 AM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: rpm all over the map
could be maf sensor is dirty or needs cleaning. gotta take off the intake system (really not that hard, 10-15 min with screwdriver) and clean around the maf sensor. that might fix your stalling problem.
did you check your brake fluid?
438whp / 373tq - 11.9 @ 126
Old 03-01-2004, 09:39 AM
Yes i checkd the brake fluid, it was ok, I will be sure to try and clean the maf tonight but would a dirty maf create such violent rpm moves?
so to you it does not sound like an electrical problem or tune up issue?
I did the tune couple of years back.
Thanks
Old 03-01-2004, 11:09 AM
yada yada yada
doesn't sound like electronical. yes a dirty maf could create a bad idling issue. if that doesn't work.... you said it happens while you're driving and stepping on the pedal, check your fuel pump. it really could be the fuel pump or a bad injector.
2001 Conv - RPMs All Over The Place - Engine Revving Artgirlfriend Sebring | Sebring Coupe | Convertible 0 02-15-2007 07:19 PM
Scratches all over the paint! Veetec Exterior | bodykits | Lighting 11 02-11-2002 08:34 PM
Black Exhaust all over the back of my car ? stucci22 Prelude 8 01-11-2002 01:01 PM
