Old 02-29-2004, 08:31 PM
cbrian cbrian is offline
97 Silverado Keyless Prog
I need some help programing my remotes on my 97 Silverado keyless entry. Thanks
Old 03-01-2004, 12:52 AM
spotco2 spotco2 is offline
Banned
Re: 97 Silverado Keyless Prog
Transmitter Programming
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation.
Document ID# 453508
1998 Chevrolet/Geo Chevy C Pickup - 2WD
Old 03-17-2004, 03:48 PM
jscites jscites is offline
Thanks you just helped me too
1996 Silverado Keyless Entry Module (where is it?) gavidoc Silverado 1 10-24-2004 11:44 AM
1995 Silverado Keyless reprograming jcaulder C/K 0 03-01-2004 05:07 PM
silverado keyless entry bowser2778 C/K 5 02-10-2004 05:42 PM
1999 Silverado Keyless remote programming (New Body) Kingclever C/K 7 01-10-2004 08:47 AM
'02 Chevy Silverado Keyless Entry Slick Silverado 0 03-19-2002 07:23 AM
