Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-29-2004, 08:21 PM
wd40 wd40 is offline
Unhappy 1996 Olds Cutlass Supreme cruise control
1996 Olds Cutlass Supreme cruise control problem.
How do you get the tape to move out about ONE INCH from the cruise control module. I believe that if I put power to one of the module terminals the motor will turn. Which terminal? I don't want to burn the board. There is not enough adjustment in the cable to get what I need.
I just replaced the intake manifold gaskets on a 1996 Olds Cutlass Supreme. When I removed the cruise control cable from the throttle body the cable pulled into the cruise control module and now is too short to connect to the cam at idle. It holds the cam at about 3000 rpm. Any suggestions?
Possible Exhaust Back pressure on 96 Olds Cutlass Supreme chrisluna Cutlass Series 4 10-16-2009 05:01 PM
1996 Olds Cutlass supreme.... nccman19 Cutlass Series 3 04-07-2006 06:34 AM
1996 Olds Cutlass Supreme sometimes it starts, sometimes it doesn't?? pretendingsanity Cutlass Series 5 08-25-2005 08:46 AM
1996 Olds Cutlass Supreme 3.1 trouble starting??? MeanWS6 Cutlass Series 6 06-01-2004 03:12 PM
Spark Plug & Wiring problem on 1996 Olds Cutlass Supreme WillKool1080 Cutlass Series 0 07-29-2003 08:09 PM
