Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-14-2009, 05:26 PM
chrisluna chrisluna is offline
Possible Exhaust Back pressure on 96 Olds Cutlass Supreme
1996 Olds Cutlass Supreme, thought it had a rough idle but further investigating leads me to believe that the car/engine shaking is caused by back pressure in the exhaust. Looking at the exhaust from under the car, the exhaust pipe shakes bad. At the end of the exhaust pipe there is not a free flow of gases, the exhaust comes out inconsistently. What can cause this? I am not having any check engine lights come on. I changed spark plugs, wires, mass airflow sensor, and fuel filter.
Old 10-14-2009, 06:28 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Possible Exhaust Back pressure on 96 Olds Cutlass Supreme
Possible its the converter clogged, especialy if its the original.
How many miles on this 3.1 ?
Could also be a muffler issue, clogged or something inside came apart adn blocking the exhaust.
1999 Grand Am SS 3.4 OHV
Old 10-14-2009, 07:47 PM
Yes, it is a 3.1 and there are about 143,660 miles on it. I was thinking possibly a clogged catalytic converter too. Someone suggested that I just knock out the core and not even worry about replacing it. My concern about that is wouldn't that cause problems with the sensors?
Old 10-16-2009, 02:50 PM
knocking th ecatalist outa the converter isnt that easy.
It would affect the sensors if it has a O2 sensor after the converter.
Old 10-16-2009, 05:01 PM
if I change the converter will i have to replace the O2 sensors also? there is an awful smell after I drive. I have heard that if the cat is bad it can smell like rotten eggs. I can't tell if it smells like that but it sure does smell bad.
Tags
1996 , back , cutlass , pressure , supreme
