I have a 2004 honda accord. I need to know how to remove the honda and accord decals. I know they are just glued on, anyone know how to safely remove these? Thanks.
Re: How can I remove the decals on my accord?
glued...if u want to take it off cleaner, get a blow drier and heat it up and then a cloth under a flat head and then peel away....
the H i think is pinned, it will pop off sorrie for a late reply but automotive forums isnt the best out there, plus moderators dont do shit here.
![]() www.cb7tuner.com <---90-93 accord board :for sale: left and right motor mounts for 4th gen accord. great condition :strut bar, rear..no brace... ... |
you can also take a blow dryer to it, heat it up. take some floss or fishing string/wire and slowly put it under and work it underneath the decals. after your done, carefully take a razor blade to the glue and then make sure u use like goobegone or sumthin like that... wash ur car after..wax a lot...too.
The way Honda described it is exactly as the above (although the blow dryer isn't always necessary). Beware! Do not attempt to use a flat head screw driver or other sharp objects to remove the glue! If you do (like I did) you will likely scratch the hell out of your paint. You may wish to try Isopropyl Alcohol, I found it works pretty well. Avoid nail polish remover or anything with acitate however, that will fuck up your clear coat!
