Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-27-2004, 09:05 PM
lcmb25 lcmb25 is offline
Exclamation Does anyone know codes PO440 and PO446?
I just bought a 1997 Maxima about a month ago and love it. I had my engine light come on and the codes are PO 440 and PO 446. Can anyone please help me. I am also looking at putting on a cold airintake and any info on those would be awesome
Old 02-27-2004, 09:10 PM
Blackwind 98 SE Blackwind 98 SE is offline
Re: Does anyone know codes PO440 and PO446?
whats your location?
98 maxima se: 5spd swap,mevi, and soon to come v2 supercharger,fidanza flywheel and more reasons to make ricers swap thier engines!!
The MP checkpoint is not an Imperial Stormtrooper roadblock, so I should not tell them "You don't need to see my identification, these are not the droids you are looking for."
Old 02-29-2004, 05:36 PM
Utah. Can you help me??
Old 03-16-2004, 10:26 PM
havic havic is offline
I know you posted a long time ago but if this helps
Diagnostic Trouble Code Description
Trouble Code: P0440
Vehicle Qualification: Nissan Maxima
Description: Evaporative Emission Control System
Trouble Code: P0446
Description: Evaporative Emission Control System Vent Control Circuit
Old 06-03-2004, 03:41 PM
johnnyproduce johnnyproduce is offline
Re: Re: Does anyone know codes PO440 and PO446?
Trouble Code: P0440
Trouble Code: P0446
Hi, I understand that much but what do I have to do to fix the problem??
Old 06-24-2004, 11:56 PM
habenero2002 habenero2002 is offline
Send a message via Yahoo to habenero2002
most of the time replacing the vent control valve on the canister will correct this problem
Old 06-26-2004, 11:51 AM
mrpreludesh mrpreludesh is offline
Send a message via AIM to mrpreludesh Send a message via Yahoo to mrpreludesh
Also try changing your gas cap
Old 07-22-2004, 10:25 PM
OK, I fixed the 446 code by replacing the evap cut valve, located on the charcoal canister. It's the part opposite the muffler previously mentioned in the thread. NOW, I replaced the gas cap and replaced my purge control valve and 440 keeps coming up HHHHHEEEELLLLPPPP!!!!!!!!
Old 08-20-2004, 02:13 PM
trv_2000 trv_2000 is offline
Where is the purge control valve and is it easy enough to be replaced by novice like me?
Old 08-29-2004, 11:28 AM
The purge control valve is under the hood of the car. It's really easy to find bc it's on the top of the engine just open it up and look around you can't miss it!!
Does anyone know this Make and Model? HotRod32 Classic Cars 1 06-30-2008 10:13 AM
Error Codes PO440 and PO446 lcmb25 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 03-01-2004 06:38 PM
Does anyone know the Chassis codes? etantshi Engineering/ Technical 14 07-10-2002 01:35 AM
Does anyone know proper way to bleed brakes on P11 and proper break-in on new pads?? ty423 Maintenance 5 03-02-2002 07:51 PM
