Old 02-27-2004, 01:48 AM
youngmanvr4 youngmanvr4 is offline
Engine rebuilding
When i rebuild my engine should i put new forged rods, pistons, steel crank, main studs, head gasket, camshafts, valves, valve springs and retainers in when i rebuild it?I'm going to have GT-Pro 368 turbo's in it so i dont know if that matters on what i should do on the rebuild.I will also have the heads ported.Any tips or advice on what i should or shouldn't do would be awsome.
Old 02-27-2004, 10:55 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
If you can afford to do all those things, you'll be better off for it.
You don't need to do any of those however.
What are you doing with the fuel system to get the most from those 368s?
Resistance Is Futile (If < 1ohm)
Old 02-27-2004, 11:26 AM
Re: Engine rebuilding
Denso 310 lph fuel pump, Denso 660 cc injectors, S-AFC.Any advice on that?
2000 z71, 5.3 budget rebuild, any tips nthnkng33 General Discussion 2 07-20-2010 09:06 PM
1994 f150 5.0 rebuild spoovey F Series 4 03-19-2010 06:30 PM
Engine Rebuild abc234 Aveo 1 05-17-2009 06:38 PM
Complete Engine GASKET ( engine rebuild kit ) for GTR34 UAEBOY Performance 3 02-07-2003 11:11 AM
engine swap or engine rebuild hnodaman Engineering/ Technical 1 10-14-2002 12:32 PM
