Old 02-26-2004, 01:23 PM
chrsmoos chrsmoos is offline
99 Intrigue Engine Knock
Hey all,
I have a 99 Olds Intrigue GLS with the 3.5L Shortstar engine.
It has a definite knocking sound that occurs on startup, not too noticeable in the car with doors closed, but definately there.
It has not gotten any worse and oil consumption is about average for what I hear for this car. Sometimes needs more between changes and other times it does not need any additional.
Crankshaft postion sensor already replaced.
What could this be? Think it is a definite sign of impending engine failure or is it something that will just be a minor annoyance?
Sounds like bad lifters, or bearings, but i am no mechanic.
Car has 65,000 miles and runs well otherwise.
thanks,
Chris
Old 02-29-2004, 10:39 PM
illinoiswronski illinoiswronski is offline
Re: 99 Intrigue Engine Knock
It depends a lot on the exact sound. "Engine Knock" is normally defined as the sound that an engine makes when you begin to get detonation due to too much timing and/or too low octane, in the old days people called it "ping".
I think it is likely that the startup noise you talk about is called "Piston Slap" which is relatively common in GM engines. I notice it in my car esp during the winter.
If you google "Piston Slap" you will likely come up with a week's worth of good bathroom reading material on the topic. The basic summary that I think you will find is that GM will tell you that it is completely normal and does no harm, and the internet pontificators will tell you that it means your engine will surly melt down to molten slag in the next 100 or so miles. If you read anything significant please post it as I have not read up on it much for quite some time.
FYI, the "shortstar" engine is the 4.0 Liter V8 offered in the Olds Aurora which is a smaller displacement version of the 4.6 Liter Northstar V8 used by Caddy.
Old 06-10-2004, 06:48 PM
TINNY TINNY is offline
My 99 Had The Same Problem. Took It To My Dealer To Find The Oil Pan Gasket Had Sucked Into The Intake. Lost All Oil Pressure. Cost The Extended Warranty Company Sbout $500.00. Hope Thats Not You Problem. Good Luck.
knocking after oil change 3.1 moemo Cutlass Series 1 10-20-2010 06:37 PM
1998 Mustang V6 engine knocks and runs rough birdstash Mustang Problem Diagnosis 2 06-04-2009 09:59 PM
98 intrigue engine light jgirl1350 Intrigue 2 02-25-2004 05:29 PM
