Old 02-26-2004, 12:14 PM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
Unhappy code 16
ok so i know a code 16 is a fuel injector but how should i go about fixing it because my car has the mpfi conversion and it doesnt do it all the time the only time is usually when its warmed up and i start it up hot but this is where it gets kinda sketchy it doesnt do it all the time its only done this 4-5 times and i drive it daily i would like to fix it before i end up on the side of the road
thanks in advance
Old 02-26-2004, 12:25 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Did you do the MPFI wiring yourself?
Check all your connections and make sure they're good and solid.
Honda Enthusiast
Old 02-26-2004, 03:08 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: code 16
I've got that code also. Does ur car ever bog down like not accelerate as fast when u get that code? I was getting that code also but for me it was just because the plugs weren't staying on. I lost all the metal clips that hold the injector plugs on so when I would go over a bump, they would pop off, my car would bog because their's no fuel being injected into that cylinder only air and spark, then I would get the code 16 popping up. But it would be fine if i popped the hood and pushed down the injector plugs all the way. I just actually fixed it today cuz I went to the junkyard and got the metal clips. Come to find out, the clips can be sourced from almost any hyundai, nissan, and saab as well as honda and acura. The style of injector plugs on a honda/acura are called "bosch" plugs. Many different makes use bosch plugs for alot of their sensors. I got mine from some sensors on a hyundai wiring harness.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 02-26-2004, 05:28 PM
adtinio adtinio is offline
sorry to hijack but my ecu is throwing this code as well. the difference with my car and other cars that are throwing this code in this thread is that my car won't start. the car cranks but won't turn over. i also noticed that when i turn the ignition switch to the on position, my instrument cluster does not light up. any help with diagnosing this would be very appreciated.
BTW, i've just recently replaced my main relay, igniter, and coil. My car is DPFI if that makes any difference.
Old 02-26-2004, 08:21 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: code 16
your ignition switch might be bad, my did the same thing when it went bad, the car would try to start but as soon as i let the key go from the start position it would stall.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 02-26-2004, 10:38 PM
Re: code 16
maybe i should be more specific well everytime it does this it runs really rich and like doesnt want to run i know its not my connectors on my injectors cuz they are good i guess i'm gonna spend all day saturday re wiring my injectors once i do a couple test
Old 07-29-2004, 03:05 PM
sgracik sgracik is offline
Re: code 16
I know this was a while back, but I wondered if you ever figured out what it was. My car did this once and a coworker told me how to fix it. In my case, he turned the key back to accessory setting and then back on and it fired right up. He said it resets the fuel injector. Hope this helps.
Old 07-30-2004, 02:08 AM
DirtyD777's Avatar
DirtyD777 DirtyD777 is offline
Send a message via MSN to DirtyD777
well dude, my car was throwing a code 16 and I KNEW it wasn't the injectors..so I replaced the o2 sensor on a whim and bam all better..don't know if that helps you though sorry
Old 07-30-2004, 07:00 AM
Re: code 16
Hey, thanks for that. Mine is throwing a code 16 also. That's how I found this forum, I was looking for troubleshooting tips. My car runs fine, but my check engine light comes on. It goes off for days at a time then comes on again, until this week. Now it comes on every day about 5 minutes after I start driving it. How hard is an 02 sensor to replace and are they expensive? I bought the Chilton's book for this car, but haven't tried to do anything to it yet other than change the intake.
Old 07-30-2004, 08:45 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: code 16
I've been a lazy ass and haven't gotten my O2 sensor yet. But I'm definitely getting a Bosch one from Advanced Auto or Auto Zone cuz Honda wants like $180 or something for one. F that! After reading Bambam say that all the sensors are pretty much universal Bosch parts I think it's a f*cking rip off. BTW... Bosch O2 sensor is $17. Oh, and I got this stupid bog thing and I might have a short... not sure, just know my A/F gauge is going nuts! But I'm going to do the O2 thing first cuz everything else seems good: wiring, plugs, wires, injectors, main relay, etc.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 07-30-2004, 09:54 AM
Re: Re: code 16
I replaced my ignition switch. No problem since...
Old 08-02-2004, 10:16 PM
RedLineZO6's Avatar
RedLineZO6 RedLineZO6 is offline
my car was givin me the same code, and i took it to the dealer, they said it was the main relay, which controls both ignition and fuel delivery. So i bought a new relay, about 37 bucks if i remember correctly, after a bit of ninja body folding to fit myself down under the dash and change it, i havent had a problem since, no more code 16 and engine doesn't run as rich.
Hope this helps!
Old 08-03-2004, 07:15 AM
Re: code 16
Hey, thanks for the tip! I'm determined to get to the bottom of this thing. I took mine to my mechanic and the light will never come on when he's looking at it. He said not to worry about it if the car seems to run good, but I can't stand that light shinning back at me all the time. I bought the Chilton book and joined this forum and come hell or high water, I'm going to figure this thing out.
So is it pretty easy to change the main relay then, besides the obvious disadvantage of location? Do I have to buy the main relay from the dealer or do places like Advanced Auto sell it?
Old 08-03-2004, 02:21 PM
DirtyD777's Avatar
Re: code 16
omg that's funny.
but seriously.
o2 sensors are really easy to replace..just unscrew old one put it in the wire and scew it back in...(if it's not oem o2 sensor you may have to splice it into wire because it wont' have the connector pin thingy) just make sure to get a good connection and it should be good...I've found that the universal ones work just as well ..in my experiance anyways as oem.
Old 08-11-2004, 09:02 AM
Re: Re: Re: code 16
Well, I replaced my main relay and reset the code. The behavior has changed, but I'm still getting the light. Now, the light comes on at exactly the same spot every weekday morning. I drove it all weekend and it never came on, for the past three days it has come on about 5 minutes after I leave in the morning. I can turn the car off right then and restart it and won't see the light again until the next morning.
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
'98 Blazer - Codes, codes, codes! MAF & O2 LAN2UNOW Problem Diagnosis 3 03-02-2008 08:56 PM
codes,codes,codes vdubdad Beetle - New/New Beetle Convertible 0 10-22-2007 08:33 PM
Codes, codes, codes.... alkemist Riviera 7 06-19-2006 06:52 AM
Codes, Codes, CODES!!! patrickkdunn Contour 8 05-01-2004 04:31 PM
