Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-26-2004, 12:28 AM
fastrails fastrails is offline
I got a CEL with code 1404 after cleaning out the EGR Valve
I cleaned out the EGR valves over the weekend and got a CEL with code 1404 after a couple of days. Car seems to be running much better than before. I bought a Universal Code Reader OBDII, and that is what it read. Any help would be greatly appreciated. Thanks in advance.
Old 02-26-2004, 12:40 AM
Re: I got a CEL with code 1404 after cleaning out the EGR Valve
BTW, the code was cleared by the OBDII.
Old 02-26-2004, 08:57 AM
amigo-2k amigo-2k is offline
Isuzu Guy
I had a CEL too when I cleaned mine. I drove the truck for abour 15 minutes after cleaning and the light would flash at me. After my next restart it turned off. I wouldn't be to worried about it.
-Ryan
1404 is a stuck egr valve. Maybe you didn't clean it well enough? did you try to move it a bit with a screw driver?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-26-2004, 11:34 AM
rodeo02 rodeo02 is offline
Like Ryan says, you want to make sure you work the EGR valve pintle up & down during the cleaning process to make sure it moves freely. The EGR valve itself rarely, if ever goes bad. It's just a simple solenoid with one moving part (pintle). Many shops just want to replace them ($$$) because they are used to the old vacuum diaphragm type EGR valves, where the diaphragm would blow out & the whole valve assembly would need to be replaced. The electrical EGR's that the newer zu's have should easily last the life of the truck. You just need to clean the plumbing regularly (very common in ANY modern, EGR equiped vehicle).
G/luck
Joel
Old 02-26-2004, 12:03 PM
I just cleaned the two holes with a whole bottle of GUMOUT carb cleaner. Do I also need to clean the EGR unit itself? And how should I do it? The code 1404 on my Creader manual saids it's "EGR Solenoid Control Faulty."
Old 02-26-2004, 12:38 PM
Isuzu Guy
Yup, spray out the inside of your EGR. I sprayed mine out (I but I didn't try to move the springed pintle, didn't know at the time), and then let it set for about 30-45 minutes. I was a bit afrid to hook it right back up and start it up, since you have electrical stuff.
I'm thinking about taking some more screen shots of my cd manual and put together a write up this weekend.
-Ryan
-Ryan
Isuzu Moderator
Car Show Tips
Old 02-26-2004, 05:19 PM
Re: Re: I got a CEL with code 1404 after cleaning out the EGR Valve
How do you take EGR apart? It looks like a single unit.
V
-Ryan
Old 03-10-2004, 05:46 PM
Isuzu Guy
-Ryan
Isuzu Moderator
Car Show Tips
Yet another question about cleaning the EGR valve Fluvannahoo Rodeo | Passport | MU 5 06-30-2006 12:53 PM
How do I clean the EGR valve on my 97 Cavalier jan6_76 Cavalier 0 09-26-2005 10:56 AM
1992 4runner how to clean the egr valve dlrblkjack 4Runner/GX470 0 09-04-2005 10:21 AM
replace OR clean the egr valve ???? 1995oldsaurora Aurora 3 07-22-2005 08:17 AM
Cleaning out the garage and got stuff FS!!!!! Chhuong '88 - '91 Civic | CRX | Wagon | Shuttlee 3 08-04-2002 01:27 AM
