Old 02-24-2004, 07:04 PM
livewire_cjp livewire_cjp is offline
Exclamation Different Brake Light Problem
I have a 1995 Windstar, who for the pastfew months has been blowing the fuse or the brake lights. Well today fixing the fuses does not help and there are no brake lights and you have to putz around to get the van in gear. I have changes the brake light swith to no avail, HELP
Old 02-24-2004, 08:21 PM
rodeo02 rodeo02 is offline
You have a short to ground somewhere in the brake light circuit . It typically would not be the switch. You will need to locate & trace the wire harness for the brake lights to see where the bad connection or cut in the insulation is . This could also be caused by a bad lamp socket in one of the tail lights. I'd start troubleshooting by testing the brakes with one lamp at a time removed from the brake lights. Which ever one stops blowing the fuse when removed would be your problem area.
G/luck
Joel
Old 03-02-2004, 09:39 PM
Smile
Finnally solved it! The Previous owner had installed an after market Cruse control. and in doing so wire tied the brake cable with the cruise wires near the steering column, the rubbing of the steering column actually wore thru the wire to the brake switch.
2004 Sentra 1.8S-No brake lights?!? brynfrt05 Sentra | 200SX (USDM FWD) 11 06-08-2010 09:30 AM
1999 Passat - Changing Brake light bumpsetspikeki11 '97+ 0 03-09-2010 07:38 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 10:19 AM
Brake Light Switch uspres2020 Escort 5 09-28-2009 12:11 AM
Brake lights problem corollastudent Corolla/Matrix/Voltz 1 07-20-2009 12:39 PM
