Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-24-2004, 04:59 PM
Noremac Noremac is offline
Send a message via ICQ to Noremac
Highest amount of boost
subject says it all.. what car/setup and how much..
I've seen dyno charts for an ls-vtec boosted at 29 psi making 647 ponies, but i think thats the highest amount of boost ive seen.
95 ls with GSR head
aem cai, dc sport header, greddy exhaust, pyr computer chip(red-8500) type r pistons, skunk 2 intake manifold and coilovers, aem fuel regulator, msd ignition wires, unorthodox underdrive pulley And Now Skunk2 stage 2 cams but not installed..
all sleepin in a black body...
Old 02-24-2004, 05:17 PM
boosted331 boosted331 is offline
Go look at the dyno vid of duc's car on groundzeromotorsports.com, I think it's his 700 WHP vid. Top fuel cars run 40+ PSI, as do diesels, and i've seen a few supras over 40 PSI. What exactly do you want to know.
Old 02-24-2004, 09:41 PM
i forget to mention.. honda or acura cars only..
95 ls with GSR head
Old 02-25-2004, 02:30 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Also, what type of forced induction do you want to know about? Boost from a turbo and boost from a super are two different things and can't be measured equally.
Also, boost doesn’t completely equate horsepower, airflow does.
Old 02-25-2004, 09:24 PM
Doubletap Doubletap is offline
Send a message via AIM to Doubletap Send a message via Yahoo to Doubletap
Re: Highest amount of boost
But why, are you really gonna do anything like that or are you just filling up space with lame questions?
DoubleTap
Old 02-26-2004, 07:13 AM
Supercharger or Turbo, either one..
And i never said that it did equate horsepower??
95 ls with GSR head
Old 02-26-2004, 07:15 AM
Re: Re: Highest amount of boost
DoubleTap
I'm not sure i understand your question?? why would i post something like this??
95 ls with GSR head
Old 02-26-2004, 10:35 AM
DarkEternal's Avatar
DarkEternal DarkEternal is offline
Don't mind any negative comments. We're just trying to figure out why you want to know how much boost you can run and how much horse you can get.
Do some research on what your LS block can do. If your internals are forged, you shouldn't have a problem running on 20-25psi. You'll probably get anywhere between 300-450hp...not whp, mind you. No matter how many ponies you motor makes, you'll never get them all to the ground. If you're talking supercharger, make sure you have eveything you can cram into your car to help keep that engine cool. You don't want to race an M3 and blow your motor, right? If you're talking Turbocharger, re-evaluate what you want of your car. If you're gonna run 20psi on a daily driver...I hope you love rebuilding your engine every 30k miles. The bad thing about turbo's are how hot they run. True, there are things you can do to prolong your turbocharged vehicle's life, but you're poisoning/overheating your motor evertime you run over 10psi. Keep in mind, a turbo is feeding your car's exhaust back through the intake. If you can smoke a whole pack of Marlboro Reds while running 2 miles and NOT collapse, boost up! But if you can't do it, don't expect your car to do something comparible. Engines (like humans) NEED fresh air. The more psi you boost with a turbo, the less fresh air your motor's getting, and the more likely it is that your motor will blow.
Don't get me wrong. If you're car is going to be track only, and you have the money for frequent rebuilds; Turbo all the way! Go ahead and boost 28 or 30psi. But if it's your daily driver...consider a supercharger or Nitros if you really want to be force induced.
Either way, it's ultimately your call. A lot of people find turbochargers very rewarding depsite the higher maintains requirements. I'll be the first to admit; the sound of a blow-off valve...I get off on it. Something about it gets me ready to drive to the death.
Do your homework, and findout for yourself what you can and what you don't want to do with your car. Good luck on all your decisions.
'93 Del Sol Si
D16z6
APC short ram intake
K&N Air Filter
APC strut bar
APC Performance muffler
generic breathers
ACT Stage 1 Racing Clutch
---~things to come~---
I'm not tellin'....
Old 02-26-2004, 11:10 AM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
someone please explain to dark eternal how a turbo application works. im trying to do my math homework and really don't feel like writing a long post, thanks.
Old 02-26-2004, 12:48 PM
tibby01 tibby01 is offline
sorry, got class....
darketernal, just read this....
http://auto.howstuffworks.com/turbo.htm
and please dont try explaining something if you are not ABSOLUTELY POSITIVELY SURE you know what you are talking about.
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
DarkEternal... please... step AWAY from the turbocharger! you don't know the first thing about them...
Old 02-26-2004, 08:14 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
Listen... if you really are asking this question as far as how much boost a honda motor can handle just do a search in this forum, this topic has been brought up before... but to put it short if you are wanting to run good amounts of boost look into rebuilding your block first cause not only will your stock internals eventually go but your aluminum block won't last too long either and you'll not only be needing new rods, pistons, etc but also a whole new block (obviously depending on how much boost you run, more boost, more damage)... anyways do a search in the forum and by the way you asked the question it seems you're wanting to run serious levels of boost, look into internals first.
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 02-26-2004, 09:11 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
can u be suprized he uses mainly APC products after reading his post?
Old 02-27-2004, 12:09 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 02-27-2004, 08:29 AM
hey guys, i personally am not wanting to run boost. I was just wandering if there was anyone on this board who was running really high boost to see what kind of setup they were running.
95 ls with GSR head
setting amount of boost unknownluder69 Prelude 1 01-15-2005 10:59 PM
Do different turbos mean different amounts of boost? Thepeug Forced Induction 5 11-10-2003 02:43 AM
is it safe to run this amount of boost? Mac33R Performance 9 06-02-2003 03:57 PM
amount of boost out of turbos ?? 96LSIntegraRocket Forced Induction 3 04-29-2002 03:45 PM
Highest boost output from JRSC? BoosterSH Forced Induction 1 02-23-2002 10:51 PM
