Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-27-2002, 02:19 AM
96LSIntegraRocket 96LSIntegraRocket is offline
Angry amount of boost out of turbos ??
with some thing like a greddy turbo kit,... whats the max lbs of boost the turbo will put out lets say with good built up engine??? and a shop that does all the tunning,...
Old 04-29-2002, 03:13 AM
MARKUSIUDIUS MARKUSIUDIUS is offline
ANYTHING
It depends on the size of the Turbo. All turbos are different some ranging from 0-6psi at 4000 rpm and some from 0-20psi. It depends on the application. A turbo that creates 6 psi at 4000 rpm on a 3lt engine would not be the same at 4000 rpm on a 2lt engine. You must first work out what psi your car wants to hold and go from there.
Basically unless you change your internals do not exceed 6-8psi and you should be fine. If you want to spend a mid ammount of cash, with a few pistons and a stronger bottom end you can go up to say 10-14psi.
Im in Oz so for locations of shops you will have to ask someone else.
:flash:
1994 2.2lt Jap import Vtec, Blown with a 1GGZE charger 300Hp or 220+kw
Malpassi Reg, 500 injector, Unichip piggyback management system, Top gun leads, Map controller, Vtec controller, Custom FM Cooler, Custom fast flow exhaust and weight reduced (2640pds)
Old 04-29-2002, 02:04 PM
I'm looking to swap out all the internals,.... so if i buy like the greddy kit then i can just get a bigger turbo for more boost? oh and my last question i ment to say how much boost would i expect from the greddy turbo kit, if a shop nearby did all the tunning,....... thanks :help:
Old 04-29-2002, 03:45 PM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
the amount of boost is going to depend on the size of it. you can get a turbo kit real cheap if you only want like 10psi. i used to have a b18b ls/vtec setup with a garrett T28 and i liked it. it gave me a little more than 240 with a pretty descent rebuild..but it wasnt too expensive for it all. now i have a b16a from a 2000 si. i did a full rebuild and got a garrett T3/T4. it can push out around 30-40psi..where the T28 could maximum 10-12psi.
if you want big gains with an ls engine you are going to need a bigger turbine though...one major problem with honda engines is their small displacement..but with some nice sleeves, lower compression pistons, stronger rods...you can shove a lot more turbo in there.
i cant help you out with shops..im imagining we are far away. but its a cool thing to learn on your own...if you have help from someone who knows whats going on.
"turbo"...it just has a nice ring to it...
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
Cobalt LS Turbo Flutebuddie Cobalt 0 09-24-2010 05:54 PM
Ford Probe 1992 2,2 turbo ptq Probe 0 04-13-2009 03:30 PM
Boost Controllers/turbo timers MK2TurboCharged MR2/MR-S 1 04-16-2003 06:59 AM
Eagle or Crower Rods for High Boost from Turbo compwc18 Engineering/ Technical 0 12-01-2002 04:27 PM
Normal boost for Turbo?? bcsintegra Forced Induction 1 10-31-2002 10:34 AM
