Old 02-24-2004, 01:32 AM
Mr=P Mr=P is offline
airbrushing tamiya X-18
I'm pretty new to airbrushing. I am getting very nice results with the metallic colors (acrylic) by mixing about 50/50 with thinner. But, I tried airbushing X-18 semi-gloss black the other day and I got disappointing results.
I seem to be getting uneven glossiness over the flat surface. Any tips and suggestions on what I might be doing wrong?
Thanks
Old 02-24-2004, 05:15 AM
935k3's Avatar
935k3 935k3 is offline
When spraying Tamiya acrylics make sure your pressure is pretty high,25-30 PSI. Thinner to paint ratio should be more like 20% thinner to 80% paint. Also make sure you have a water trap, that could be water getting in the paint.
Old 02-24-2004, 07:27 AM
GT-Alex's Avatar
GT-Alex GT-Alex is offline
Send a message via MSN to GT-Alex
Re: airbrushing tamiya X-18
You must mix the paint very well too, i have noticed that X-18 tend to be flat at the end of the jar.
Old 02-24-2004, 12:44 PM
ZoomZoomMX-5's Avatar
I have found it to be harder to paint than others, because you can't tell when it's completely mixed. 50% thinner is too much. The other guy's are right. I find it much easier to use the TS semi-gloss from a can vs. airbrushing it consistently. The flat colors are never a problem.
My Fotki Album
Old 02-24-2004, 01:24 PM
Ken B. Ken B. is offline
Send a message via AIM to Ken B.
Try using the Tamiya rattlecan semigloss black if all else fails. It goes on pretty smooth...just a suggestion.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
