Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 01-02-2002, 11:10 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Rear Defrost Not Working
it's getting cold and my widows fog up really bad.
but my rear defrost doesnt work.
When i push the switch the light on the switch turns on.
the longest i've had it running is 1 hour and it was still not defrosting.
I took out the swith and made sure the connections were right.
then i checked the rear connections attaching to the window, and that looked fine also.
anyone know what else could be wrong?
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 01-02-2002, 11:27 PM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
Yeah mine works but only 4 lines actually heat up. whats up with that?
Old 01-07-2002, 04:32 PM
91b16sedan 91b16sedan is offline
Repalce the rear defrost fuse in the fuse box in the engine bay. That is why my rear defrost did not work and now it works like a champ
B16a
Other Mods
14.8 @ 94 mph
Old 01-07-2002, 04:57 PM
enginerd's Avatar
enginerd enginerd is offline
If you have a hatchback, look in the window for a unit that hooks up to a female connector. One of my old cars had a rear defrost that quit working and the connector was just loose.
Old 01-07-2002, 06:35 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Check every one of the defrosting wires that goes across the back window from the inside.... if you can see the copper wiring instead of the blackish insulation then that particular line is no longer functional.... if you're wondering "What blackend insulation?" you're probably screwed as far as getting it to work ever again is concerned
Old 01-07-2002, 11:53 PM
I checked all the defrosting wires and they all seem to be in good condition. As for the connectors i pushed them in nice and snug and still nothing.
Which fuse is it?
it's in the little box thing on the passenger side right?
i dont really wanna pull all the fuses to check them,
I'm scared i will reset somthing or screw somthing up :eshooter:
||JEFF| |
Old 01-08-2002, 01:28 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
when you pop the panel hiding your fuse box it should have like a chart of which one it is
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 01-08-2002, 02:42 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Also, rather then have your vent settings set on recirculate. Set it to fresh air. That will help prevent fog buld up. You can also kick the AC on, with the heat set, and that will help de-humidify the air.
Old 01-08-2002, 09:49 AM
It is a 20 amp fuse. If you are standing on the passenger side looking acroos the engine it is the third one on the left side of the fuses. I took some pics of the top of the fuse box and then the inside to show you just in case.
This is the photo of the diagram on the outside of the fuse box that shows you where the fuse is.
This is a photo of inside the fuse box that shows which fuse is the rear defrost fuse
B16a
Other Mods
14.8 @ 94 mph
Old 01-08-2002, 04:01 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Thumbs up ^^^^^^ What a GREAT way to help!! ^^^^^
You know what? That shit ^^^^^^^^ rocks...I am glad some peeps utilize their digicams to help out us peeps...
I once had a '78 Civic that had only like 3 or 4 defrost lines on it that worked. They do sell aftermarket defrosters..
I'll whip out my volt meter and try to figure out how to test the connectors at the back window and see how much voltage you should be seeing back there. But, as noted, if the defroster elements are damaged, you won't get much out of them. Window tint can often have adverse effects on defrosters too..
How's that b16 comin' b16sedan?
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 01-08-2002, 05:34 PM
Thanks alot for the pics!!
i check it all out and the fuse is in perfect shape.
I do have my windows tinted with Limo tint.
when the defroster is on NOTHING i mean nothing happens.
not a even a little drop of water being melted.
||JEFF| |
Old 01-08-2002, 06:19 PM
90civicrider
Did you just look at the fuse or did you test it with a test light. Some times there might be corrosion between the male and the female connections in the fuse box. When a fuse is busted the little metal piece inside is broken and not touching.
Shawn
the swap is coming along well. I am currently pulling the zc and I recieved the b16 today. I hope to have everything done and up and running by the following weekend.
B16a
Other Mods
14.8 @ 94 mph
Old 01-09-2002, 12:52 PM
sastanley's Avatar
AF Premium User
91b16sedan - Good to hear on the swap!! Keep at it and keep us up to date!
Jeff - Sorry I was a big slacker and I forgot to check with my meter. I have a Q for you....have you had any other problems with electrical stuff in the back of your vehicle? My '85 Civic once had ALL the taillights & brakelights stop working. When they put the car together there is a big-ass connector (on my '85 it was between the front and back door under the carpet/door trim, right at about the B pillar) This connector connects the back half of the car's electrical system with the front half...Mine was not making a good connection. I took it apart and sprayed contact cleaner and it helped a lot. I occasionally have my 3rd brake light in my '91 not work and I suspect the same problem..so far opening and slamming the door while my foot is on the brake fixes that!! - lol - also...your switch could still not be getting current to your defroster, even if the light is lighting up. I am sure there is a relay somewhere in the car for the defroster and it could be bad or have a loose wire..etc.etc.. The first test for you is if you have voltage at the defroster itself. Sorry I forgot to check, I'll try to remember tonight.
Later!
2003 cavalier rear defroster not working snooprawb Cavalier Problem Diagnosis 2 03-09-2006 04:18 PM
Rear defroster not working, where is the relay? LeSabre97mint Windstar 6 12-05-2005 07:05 AM
99 Cherokee Sport Rear Defrost Not Working alay73 Cherokee 3 01-19-2005 06:10 PM
Rear defroster not working Kilroy3 LeSabre 1 01-12-2005 11:31 AM
Rear Defroster Not Working ejrz01 Accord/TSX/Accord Hybrid 0 01-22-2004 01:01 AM
