Old 01-11-2005, 04:46 PM
Kilroy3 Kilroy3 is offline
Send a message via AIM to Kilroy3 Send a message via Yahoo to Kilroy3
Rear defroster not working
The rear defroster on my 1989 Buick La Sabre is not working. I don't know where the fuse block is to check it. I checked the side panel on the dash board and no fuse there. Where do I go from here?
Thank You.
Old 01-12-2005, 11:31 AM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
Re: Rear defroster not working
I believe that the fuse block is located under the wood grain panel just to the left of the steering column, where the light switch is mounted. To get it off, you have to open the drivers side door, and turn the two pins that hold the panel on counter-clockwise, and pull them out (they won't come out all the way). The panel should then just pop off.
1986 LeSabre Limited L67 sleeper
Fully ported & polished, shift kit, CAI, F41 polyurethane suspension, headers & 3" exhuast,
