Old 02-23-2004, 01:07 AM
pinkprincess pinkprincess is offline
sohc conversion to dohc vtec
i have a d17a1 sohc and i'm interested in converting it to a b16 dohc vtec... what is the best way to go about that and what are the minimum number components i would have to replace so i can avoid doing a whole engine swap??
princess
Old 02-23-2004, 01:35 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Unfortunately your only option is to swap. A SOHC motor can't be converted into a DOHC motor. Well it can be theoretically, but it would cost FAR more than it's worth (thousands of dollars you'd be talking). As for your particular Civic with it being a 7th gen version ('01 model) I'm not sure off hand how easy a B16 swap would be since the engine mount points are almost certainly different than that of earlier Civics that the B16 will drop into perfectly. I'm also unsure if a K20 motor will drop in as easily, but it may work better...
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 02-23-2004, 06:29 AM
xproductionz's Avatar
xproductionz xproductionz is offline
Send a message via AIM to xproductionz Send a message via MSN to xproductionz Send a message via Yahoo to xproductionz
Re: sohc conversion to dohc vtec
if you want a RSX engine its a pretty much a direct drop it.. just gotta use different motor mounts that i had to order...but it was almost like drop n' drive
Old 02-24-2004, 12:32 AM
hey thanks for the input...i was looking into an rsx engine...but i guess i'm not gonna leave my options closed...too bad my budget wont help.....thanks again
princess
Old 02-24-2004, 01:36 PM
emerge's Avatar
emerge emerge is offline
Send a message via AIM to emerge Send a message via Yahoo to emerge
K20A2 = RSX engine
K20A3 = Si engine i'm pretty sure that's right...
Anyways, check into the motor. I agree it's definitely more likely for the swap to possible as opposed to a b-series motor. Just try to find a wrecked RSX...
Stephen Gladney
Original PH Member
EJ8 Civic | AIM: nxzo | www.rtek.org
Old 02-24-2004, 01:49 PM
mycivic's Avatar
mycivic mycivic is offline
B series motor...Dont do it on a 7th gen civic.
K20 motor...Is more of a swap for a 7th gen civic. My cousin told me (am not sure though, still have to research "more") that the K20 fits perfectly on the 7th gen civics. They have the same mounts as the RSX. Honda/Acura where you can get K20's are as follows:
Acura RSX 160 hp
Acura RSX-S 200hp
Honda Civic Si 160 hp
(then theres the type-R K20 at 220 hp, not sure what car but you have to import it from Japan.)
2003 Honda Civic LX
Mods: Bone Stock
Old 02-24-2004, 05:00 PM
NW_H23lude NW_H23lude is offline
Send a message via AIM to NW_H23lude
the ITR engine in Japan is a K24(2.4 liter), i believe. Good luck on importing one of those tho...
Old 02-24-2004, 05:06 PM
my local shop in my area can import a k24 but for that price you can get 2 RSX-S engines..but like i said before.. i have an RSX(-S) (if you wanna be engine specific) and it was a simple drop and drive but had to order the mounts
1.6L VTEC D16Z6 SOHC to DOHC Conversion? panblackrose '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 04-29-2006 12:37 AM
SOHC conversion to DOHC. Is it Possible? Vizion0769 Lancer 2 02-08-2005 03:08 PM
problem with a sohc to dohc conversion drifter1283 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 22 08-16-2004 10:27 PM
Sohc/dohc Vtec Model Types? DOC-50N '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 12 07-05-2003 05:44 PM
SOHC to DOHC conversion? e_a_olson Engineering/ Technical 4 02-27-2003 03:25 AM
