Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 02-20-2004, 03:10 AM
1997jettaGT 1997jettaGT is offline
5sp Tranny problem on 97 jetta, in reverse.
I have an 97 jetta gt with a 2.0 and 5sp manual transmission. When I put the transmission in reverse I get a clicking sound, it does not sound like a CV joint, it is much quieter. It does not click in the forward gears and it does not matter if the wheels are straight or turning. Any info would be helpful. Thanks
Old 02-20-2004, 01:21 PM
miro1118 miro1118 is offline
Re: 5sp Tranny problem on 97 jetta, in reverse.
My 96 does the same thing. I just deal with it. I've heard its a common problem.
Old 03-07-2004, 12:46 AM
danray11 danray11 is offline
I have a 97 jetta gt with 106,000 miles and have replaced 3 clutches andnever the trans.. I had to replace the bushings in the shifter linkage.. they were loose and causing the car to Fall out of reverse flat and even worse uphill.. I may have damaged my trans but for the last 5 years its been noisey in reverse.. I have heard it may be in the synchros???have SEVERAL mods thats the reason for the 3 clutches..
Cam,Cam Gear, Big Bore intake,Topspeed header,Cat back exhaust,P-chip, under drive crank pulley,cross drilled rotors(ft and rear), wings west body lit, motegi mr7 white wheels, m3 style mirrors,clear tail lights and ft bumper lenses...im the 2nd owner and bought the car stock with 32,000 miles, so i know this car mechanically inside out. done 90% of the work 2 clutches and all schulded maint.
Old 10-30-2005, 08:30 AM
ctuagent117 ctuagent117 is offline
I hate to be the bearer of bad news. But eventually the whole reverse gear gonna break. your only hope is a tranny swap, and if you plan on re building the reverse gear you better do it quick, also reverse and 5th i think are entwined or something, so once reverse goes out 5th is gonna exp. some problems. I have the same problem on my 97 jetta gls. havent gotten it fixxed yet, i really should but parents gonna loose job soon
Old 10-30-2005, 08:31 AM
the reverse gear is just clicking its not popping out yet? its not too late to rebuild, once it pops out than you have a very serious problem on your hands.
Old 10-30-2005, 08:35 AM
reverse has no synchro, which is why it probably broke in the first place. you have to disengage the clutch for a while before u move forward while moving back ward, just like those old hot rods, or you will grind the tranny, it may not even make a grinding sound because reverse to first has a synchro but first to reverse doesnt, so sound or no sound your grinding. you the car has two teeth, im guesing he chipped one, theres still one left.
Old 03-17-2006, 10:21 PM
afrothunder afrothunder is offline
Watch out for the transaxle (differential). Mine just blew apart putting holes in the diff housing. I had the same clicking problem. I have a 97 GT
99 Pontiac Montana Tranny problems? wilson8260 Montana/Montana SV6 9 12-22-2009 09:16 PM
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
92' S-10 Tranny problem AK47 SRH420 Interior | Exterior | Appearance 3 02-20-2009 03:41 PM
1994 Jetta Reverse Problems turky1000 Jetta/Vento/Bora 9 07-18-2008 06:24 AM
Tranny problem, where's reverse? Firewind Eclipse Problem Diagnosis 15 09-09-2006 04:48 AM
